Author Topic: Attn cab builders: What kind of hinges did you use?  (Read 1834 times)
Heartburn
  • Last login:August 05, 2004, 04:41:26 pm
« on: July 28, 2004, 01:43:28 pm »
Hi there,
I'm about 60% of the way through my first MAME cab, using the recently published "Build Your Own Arcade" book (which uses LuSid's plans).  I'm not sure I want to use European hinges, as the book recommends, because I'd rather not drill 35mm holes in the MDF.  I can't see how to use normal hinges and still achieve the 3/4" recessing.  It seems like most normal hinges assume that the door will overlay the opening, or at worst be flush with it.
For those of you who put a hinged front door on your cab, could you give me a hint about how did you did it?
jbeersm
  • Last login:May 13, 2005, 02:53:45 pm
  • Never grow up...
Re:Attn cab builders: What kind of hinges did you use?
« Reply #1 on: July 28, 2004, 04:43:27 pm »
My cabinet is only about 80% complete and I went with the European hinges which are working just fine.
paigeoliver
  • Awesome face!
« Reply #2 on: July 28, 2004, 05:29:08 pm »
There isn't a hinge anywhere on my cabinet, maybe I did something wrong?  ;D
bionicbadger
  • Last login:October 01, 2012, 10:37:26 am
  • Big Deal
    • Mame Cabinet Page
« Reply #3 on: July 28, 2004, 06:01:11 pm »
My cabinet has no hinges either, other than the tiny ones on the coin door....
I used a modified lucid plan too, just screwed the front panel on permanently and built it so that I could remove the entire back panel for access.
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
« Reply #4 on: July 28, 2004, 06:51:10 pm »
no hinges here either...but then Im using different cab plans.  You could say Im 'unhinged' :o
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #5 on: July 28, 2004, 07:20:12 pm »
I've heard you are supposed to use "flush mount hinges" on the LuSID cab. Go to this link http://users.adelphia.net/~seanhat/arcade/ and then click "Coin Door" to see what I'm talking about. Good luck finding them in stores though (I have checked many places and still haven't found them. I will probably end up having to go to a cabinet shop).
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
melarky
  • Last login:July 12, 2020, 12:49:22 pm
  • If I could be any animal, I would be a llama
« Reply #6 on: July 28, 2004, 07:34:47 pm »
Those flush mount hinges are called "European Hinges" and I found them at both Home Depot and Lowes.  Doubtful that an employee would be able to know off the top of their head whether they have them, but if you go to the knobs and hinges isle and poke around a bit, you'll find the "European" style hinges.  I used those on my coin door and on a fold down keyboard drawer on mine, and they work great.  I used a piano hinge on my control panel top.
« Last Edit: July 28, 2004, 07:35:33 pm by stew_bidasso »
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #7 on: July 28, 2004, 08:35:31 pm »
European hinges for the front panel. Piano hinge for the CP lid.
crashwg
« Reply #8 on: July 28, 2004, 08:52:07 pm »
Piano hinge for the back door and also for the CP which flips towards you and down.
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
