Author Topic: Replace the windows screens?  (Read 4542 times)
Evilpenguin
  • Last login:November 30, 2007, 06:53:35 pm
  • MegaMame
« on: July 26, 2004, 03:09:10 pm »
Does anyone know of a freeware program that will allow you to change the windows screens in Windows 2000 and replace them with ones of your own?  Any help would be greatly appriciated.
Jason
Re:Replace the windows screens?
« Reply #1 on: July 26, 2004, 04:22:27 pm »
Not sure about Win2k but you could check out BootXP (I know the title, but worth a look...)
Alternatively Twisty at MameWorld posted a way to remove the Windows loading screen altogether:
My Computer > Properties > Advanced > (Startup and Recovery) Settings.  Then add /noguiboot to the end of the 'Default operating system' string...
Postalp
  • Last login:July 16, 2004, 01:34:30 am
« Reply #2 on: July 26, 2004, 11:35:10 pm »
For my Windows XP, I just go to the website StyleXP.net or .com (I forget)
Maybe someone there can point you in the right direction.
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« Reply #3 on: July 27, 2004, 02:22:34 am »
I used software called "bootskin_free" and it changed the logo to a Mame one (but only while it says Windows is loading).
However, the "Welcome" and "Windows is shutting down" screens still show up on startup/shutdown.
How can I remove or hide these screens?   ???
« Reply #4 on: July 27, 2004, 05:26:38 am »
Twisty did post a way to do this also (lost atm as the MameWorld boards went down), but I can't remember how.  It was the same method as the thing I posted above, but just a different string.  It removed the screens, but the problem is that it showed some other background stuff which is possibly worse...
mms332
  • Last login:October 13, 2006, 01:42:02 am
Re: Replace the windows screens?
« Reply #5 on: December 28, 2004, 02:40:01 pm »
I found this website that shows an alternate way of replacing the windows 2000 boot logo:
http://www.littlewhitedog.com/content-9.html
Using a free utility called Resource Hacker you can open and modify the file ntoskrnl.exe to replace the standard windows 2000 boot logo bitmap. The replacing bitmap has to be a BMP file with a resolution on 640 by 480 pixels and a color depth of 16 colors.
The link offers a step-by-step tutorial with pictures. I am not sure if this procedure will also work with windows XP. The website also offers a huge collection of boot logos to choose from.
