Author Topic: stick plexi to wood?  (Read 1121 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: July 26, 2004, 12:19:32 pm »
what is the best way to stick plexi to MDF?
will epoxy glue react with the plexi?
or just hot glue?
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re:stick plexi to wood?
« Reply #1 on: July 26, 2004, 12:48:24 pm »
I dunno about the epoxy, but you could always test on a scrap piece.  I find hot glue never stays attached unless there's no stress on the pieces you're glueing.  I usually see plexi attached by pre-drilling holes, then screwing it on.  Or, you could go with metal clamps like the ones that hold the glass on top of a coctail machine.
spystyle
« Reply #2 on: July 27, 2004, 11:08:27 am »
I stick plexi to wood using drywall screws
« Last Edit: December 09, 2006, 12:31:26 pm by spystyle »
SirPeale
  • Green Mountain Man
« Reply #3 on: July 27, 2004, 11:18:48 am »
I just got done making a control panel.  In order to make the dust washers mount in the correct space, I routed out a hole the size of a piece of plexi that I had cut to size, and used polyurethane glue (SPARINGLY!!!!) to hold it in.  You have to clamp it, because the glue expands as it cures.
