Author Topic: Power problem need HELP!  (Read 2189 times)
Tonedog28
  • Last login:July 25, 2004, 08:17:24 pm
« on: July 25, 2004, 08:20:55 pm »
I have purchased a joust cabinet with crime city inside. I have a power problem. I have installed a new power supply so i have power but the monitor does not turn on. It is a zenith rauland 19vmcp22 if you need any more info than reply and I will answer quickly! Thanks for any help!
Tonedog28
Ken Layton
  • Guru
  • Technician
Re:Power problem need HELP!
« Reply #1 on: July 25, 2004, 08:48:34 pm »
Um.... Zenith did not make the monitor. Zenith made the picture tube itself.
Look for another model number sticker with a name like Wells-Gardner, Electrohome, etc. on it.
Tonedog28
« Reply #2 on: July 25, 2004, 10:38:26 pm »
Why thank you for the info. It is a wells-gardner # 19k4901 any sugestions?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: July 25, 2004, 11:08:52 pm »
If power is getting to the monitor's power connector, then the monitor circuit board is need of service.
Tonedog28
« Reply #4 on: July 26, 2004, 12:06:50 am »
well thank you any ideas where to start at it  thanks tonedog28
Ken Layton
  • Guru
  • Technician
« Reply #5 on: July 26, 2004, 12:21:03 am »
If the soldered-in fuse on the monitor board is not blown the board may need a capkit. This chassis is well known for bad solder joints too.
The service manual for the 4900 series may be downloaded free at mikesarcade.com
If the fuse is blown you may have a shorted horizontal output transistor and/or flyback transformer. Check the B+ voltage. Is it too high? Too low? Right where it should be? Get your high voltage probe out and check the high voltage. It should be between 19,000 and 24,000 volts.
If the high voltage is where it should be you might have a break in the foil on the neckboard.
The "Black Level" control on the monitor board is in reality the brightness control. By chance it isn't turned all the way down is it?
Tonedog28
« Reply #6 on: July 26, 2004, 12:31:10 am »
thanks i get on it yeah i checked fuse its ok and the black level i did check nothing happend  but im going to check the rest tommorrow
Ken Layton
  • Guru
  • Technician
« Reply #7 on: July 26, 2004, 12:57:34 am »
The "Screen" control over on the flyback may be turned down also. It can be considered as a coarse brightness control. So if it were turned down too low you wouldn't see a picture.
Tonedog28
« Reply #8 on: July 26, 2004, 01:03:11 am »
alright thanks i'll check that also tonedog28
