Author Topic: Control Panel wood thickness?  (Read 1802 times)
megashock5
  • Last login:May 19, 2015, 06:51:16 am
« on: July 23, 2004, 02:31:33 pm »
Starting to plan my control panel and I haven't decided whether to go with all wood (with some sort of thin covering) or to make a graphic CPO that sits under lexan or plexi.
My question is, what are the thicknesses that are used for each of these? I remember seeing either 3/4" or 5/8" mentioned for the wood ones, but I haven't seen anything about the other. I supposed it would depend on the thickness of the lexan or plexi, but what would be the overall thickness to shoot for?
thanks!
photorock
  • Last login:March 07, 2006, 08:37:03 am
  • Goofy Newfy!
Re:Control Panel wood thickness?
« Reply #1 on: July 23, 2004, 02:50:29 pm »
        I think, but don't quote me on this, most go with 5/8" wood (mdf or plywood) 1/8" or 1/4" (lexan or plexi), depending on wheather you want a little bit of a lip when you apply the 3/4" t-molding and artwork between.
         There should be lots of threads here on this, becouse it's been debated a number of times. Do a search you should find lots of usefull info.
         Personally, I used 3/4" Plywood (for strenth, mine is a desktop unit attached to my computer dest), 1/8" Lexan and 1" t-molding with artwork between.
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
« Reply #2 on: July 23, 2004, 02:51:39 pm »
I do not top mine with lexan and I use 3/4".
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
« Reply #3 on: July 23, 2004, 04:01:01 pm »
I'm in the process of building my control panel.  I've used 3/4" MDF for entire cabinet EXCEPT the control panel.
For that I'm using 5/8" MDF and 1/8" plexiglass.  5/8 + 1/8 = 3/4" = the size of my t-molding.
So, that's what I would suggest anyways...
megashock5
« Reply #4 on: July 23, 2004, 04:15:58 pm »
^ sounds great - thanks for the info!
Still trying to decide which way to go, but this is exactly what I was looking for.
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #5 on: July 24, 2004, 07:38:59 am »
Yes, it basically all depends on wether or not you're using plexi on top, AND if you can even FIND any 5/8" MDF (I went to 2 home depots and one lumber yard, and none of them had any 5/8")
So for me, it was easy, all 3/4" no plexi.
BYOAC users get 5% off with coupon code byoac5
NoOne=NBA=
« Reply #6 on: July 24, 2004, 01:51:02 pm »
I use 1x solid poplar for mine, with no plexi over the top.
The actual thickness is 3/4", and you don't have the laminated edge showing like you do with plywood.
For graphics, I am using back-printed 0.010 lexan, which is what was used on most of the classic cabs.
I don't like MDF at all.
It is not anywhere near as strong as solid wood or plywood.
It is easier to form though.
