Author Topic: Getting snaps to appear in mamewah  (Read 2927 times)
derek1800
  • Last login:January 29, 2005, 03:23:31 pm
« on: July 22, 2004, 06:04:05 pm »
I have been sitting here fooling with mamewah for an hour trying to get my snaps to appear. I have a layout were it only shows screenshots so I put the path of the screenshots(c:\mame\snap) in all the artwork paths. But they wont show up. The files are png.
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
Re:Getting snaps to appear in mamewah
« Reply #1 on: July 23, 2004, 07:32:43 am »
- Check if the artwork path you added is the one on the layout. Remember that you can have up to 10 ...
sanousuke
  • Last login:March 13, 2009, 05:21:37 pm
« Reply #2 on: September 09, 2004, 04:13:38 pm »
I'm haveing the same problem.
I had it working on one computer, but ever since I transferred everything(mame folder and mamewah folder) it doesn't show the snaps. I'm thinking I need to unzip the snaps folder on this computer, but I deleted it...
terrymason
  • Last login:August 24, 2004, 11:30:03 am
« Reply #3 on: September 09, 2004, 05:47:43 pm »
You need to reinstall mamewah, as when you run in the installer it copies system files in place.
try downloading the system files from the mamewah website
sonicflood
  • Last login:August 19, 2005, 11:22:40 pm
« Reply #4 on: September 09, 2004, 11:50:00 pm »
Should the snaps remain zipped?  I have no snaps displaying either. :(
I need to d/l the latest version.
"Oh, you should never never doubt what nobody is sure about." -Willy Wonka
« Reply #5 on: September 10, 2004, 06:23:13 am »
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
« Reply #6 on: September 10, 2004, 10:26:27 am »
What are the chances of MameWah using zip fiiles for Snaps etc? The reason I ask is that CLRMAME needs the pictures to be in zip files to work with the DAT files that are supplied. So it ends up that I have two copies of all of the pictures, one zipped and one not.
This is not a big deal but perhaps there is another way to do this.
Cheers.
« Reply #7 on: September 10, 2004, 11:29:07 am »
Chances are slim atm, since I've no idea how to do it  ???
I realised the other day that ClrMAME requires images zipped with the DAT files (I've never ClrMAME'd my snaps before).  All I did was zip them up, run ClrMAME, then unzip again and delete the zip.
I'll probably take a look into it at some point, but it's not top priority atm...
sanousuke
« Reply #8 on: September 10, 2004, 01:11:26 pm »
I'm stuck..
I deleted  mamewah then downloaded it again plus the system files and installed them. I still can't get the snaps to show.
It all works on the computer I originally installed it on. I transferred the mamewah and mame folder to two other computers and I can't get the snaps to work for them. Is there some files in the windows folder or something that I need transferred to?
« Reply #9 on: September 10, 2004, 01:17:49 pm »
I'm stuck..
Yes, transferring the \mamewah folder alone is not enough.  You need to install the system files on *all* PC's you want to use MAMEWAH on.  The system files need to be installed & registered...
sanousuke
« Reply #10 on: September 10, 2004, 02:27:33 pm »
Yatta! I'm happy now, it works.
The last time I installed the system files, it wasn't in the same folder as mamewah, so that's why it didn't work. I assume.
« Reply #11 on: September 10, 2004, 03:11:45 pm »
Well the system files are automatically installed into the \Windows\System32 folder when you run setup.bat, so they don't need to be in \mamewah...
Glad it works anyway!
