Author Topic: updating mame....will i lose my high scores?  (Read 1921 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« on: July 19, 2004, 11:09:37 am »
im using mame32 and its version .71 so obviously its old.  i want to update to version .84.2 but im worried that my highscores will go away.  i have the hiscore.dat file, but will that mess up when i update my mame32?  if so, is there a way to save the highscores and then paste them in the new file or something?
SirPeale
  • Green Mountain Man
Re:updating mame....will i lose my high scores?
« Reply #1 on: July 19, 2004, 12:11:30 pm »
The hiscore.dat file only tells Mame where the hiscore info is in each ROMset.  Scores are saved in the nvram folder.  It's a crapshoot whether or not the scores will be saved correctly or not.  Some may, some won't.  Since you're going with a huge revision change, likely the answer is no.
hulkster
« Reply #2 on: July 19, 2004, 12:47:44 pm »
okay, i started thinking about it, and if i do an upgrade from .71 to .84 of mame....and i want to update the roms as well....will i have to install the updates starting at like v.71 to .72, then from .72 to .73, etc....going all the way until i get up to .84??  or can i just update the roms that are designed for .83 to .84?
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #3 on: July 19, 2004, 01:07:20 pm »
  You would have to update your ROMs incrementally.  It's huge hassle and it's pretty time consuming, which is why most people don't do it unless they have to ;)
-Steve
hulkster
« Reply #4 on: July 19, 2004, 02:03:23 pm »
well i am running mame32 v.71 but i have a complete rom set for v .80.  yeah i know, but i didnt realize i had an old version of mame until i got the roms.  anyway, i guess i could just update mam32 to the newewst version, then install the rom updates for .80 to .81, .81 to .82, etc.....up to .84.  right???
SirPeale
« Reply #5 on: July 19, 2004, 07:30:18 pm »
Who told you that bologna?  You can certainly jump to any revision you want.  ClrMAME will sort everything out, and let you know what you're missing.
hulkster
« Reply #6 on: July 19, 2004, 09:11:20 pm »
well i have the rom updates for .81 to .82, .82 to .83, etc.  my question was will i have to update the first, then the second, or can i just do this...
i have v .80 roms....i will use the .83 to .84 rom update to go to the latest version.  will that work?
SirPeale
« Reply #7 on: July 19, 2004, 10:15:21 pm »
If you have them on seperate CDs (or DVDs) ClrMAME can just pull what it needs from them.  Just put the CD path as an addpath.
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« Reply #8 on: July 20, 2004, 01:55:49 pm »
Pardon my ignorance, but I've never really understood the complexities of updating ROMS sets.
I've got a full .79 set, with updates stepping .79-.80, .80-.81, etc... Can't you just dump the .80 roms in the rom directory, then the .81 and so on? Doesn't this copy over old roms and add any new ones? Am I missing something?
Then wouldn't you use ClrMAME to just doublecheck?
I guess I'm confused by the word 'installing', it's making it sound very complex.
« Last Edit: July 20, 2004, 01:59:51 pm by mr.Curmudgeon »
SirPeale
« Reply #9 on: July 20, 2004, 02:04:22 pm »
With updates that are *just* the changed ROMs, if you dump those in you will overwrite the existing set that's in there.  Which is really bad if it's an 80M set that only needs a 500k update file.
What ClrMAME does is look in the addpaths for these updates, pulls what it needs out and inserts it into the ROMset.
mr.Curmudgeon
  • Huzzah!
« Reply #10 on: July 20, 2004, 02:36:51 pm »
So a ROM update set only features the updated <b>parts</b> of the roms?
Is there a site that clearly explains the clone/merged/split issue?
I thought it was a one-for-one swap, ie: whatever.zip (v.83) replaces whatever.zip (v.79). I hadn't compared filesizes yet, so that may have been a dead give away.
Paul Olson
    • Paul's Arcade
« Reply #11 on: July 20, 2004, 08:11:52 pm »
The best way is to rebuild the roms.  Set your roms folder as the destination folder, and the folder containing the updates as the source folder.
Paul
