Author Topic: Successor to SortInfo.exe ?  (Read 3423 times)
spystyle
« on: July 16, 2004, 08:41:28 pm »
Here's a n00b question, but I'm not so familiar with the software aspects of MAME, just building cabs ...
I use SortInfo.exe to sort my roms, but it's pretty inaccurate, what do you fellas recommend as it's successor?
Thanks,
Craig
« Last Edit: July 06, 2006, 10:24:47 am by spystyle »
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Successor to SortInfo.exe ?
« Reply #1 on: July 16, 2004, 10:27:35 pm »
Inaccurate as in how?
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #2 on: July 16, 2004, 10:29:20 pm »
Thanks,
Craig
http://spystyle.arcadecontrols.com
  Unfortunately, Sortinfo is only as accurate as MAME is. There's not much you can do, really, except talk to the MAME devs.
-Steve
SirPoonga
  • Puck'em Up
« Reply #3 on: July 16, 2004, 10:59:46 pm »
What screaming sai, I was just trying to see what you thought was inaccurate.
spystyle
« Reply #4 on: July 16, 2004, 11:08:41 pm »
I built a 3 button cab and sortinfo identified a bunch of 3 button games as 4 button games, and it identifies Mappy as an 8-way game, ect.
SirPoonga
  • Puck'em Up
« Reply #5 on: July 16, 2004, 11:41:19 pm »
yeah, that's coming from mame.  What many of the driver programmers did was create a button macro that covered all the games in the driver.  Soa  3 button game will have 4 buttons defined because it is using the same macro as the rest of the games in the driver, one being a 4 button game.
Then there is the issue of some controls aren't right, like 2way joys and dotron having a "trackball".  Many many other examples.  This is why the controls.dat project started.
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #6 on: July 16, 2004, 11:42:00 pm »
There is always going to be mistakes.  The sad story is that sortinfo doesn't work after Mame 76.  If anyone knows a fix, PLEASE post it!
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #7 on: July 20, 2004, 08:30:37 pm »
What is the problem?  I didn't notice any problem running it on version 82.1.  (using Wine under Linux if it matters - I don't imagine that it would make it work better).  I use it to generate my little database searching tool:
Here it is
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #8 on: July 20, 2004, 09:03:38 pm »
SortInfo didn't like a lot of the recent Mame releases. I'm not sure why.
For example, it wouldn't work with .81, but it worked fine with .83.
But since the -listinfo command has been permanently removed from all future builds of Mame (from .84 onward), SortInfo will never work directly with a Mame executable again.
I haven't tried using the Xml2info utility, so I'm not sure how good the listinfo it produces is, or if SortInfo likes it.
spystyle
Re: Successor to SortInfo.exe ?
« Reply #9 on: July 12, 2005, 08:37:48 am »
*bump*
Is there a successor to sortinfo.exe yet?
Also, is there a way to make it work with MAME versions beyond .84?
Thanks,
Craig
JoyMonkey
    • JoyMonkey.com
« Reply #10 on: July 12, 2005, 09:06:46 am »
I haven't had any problems with .84 or above - converting the listxml to the old listinfo format with xml2info does do the trick.
I think Screaming did put together a utility with the same (if not better) functionality as SortInfo that works directly with the newer Mame versions. I can't remember what it's called or where to get it right now. Must search...
Edit: Here's Screaming's ListGen thread I was thinking of:
http://forum.arcadecontrols.com/index.php?topic=36762.msg335037#msg335037
« Last Edit: July 12, 2005, 09:11:49 am by JoyMonkey »
spystyle
« Reply #11 on: July 27, 2005, 07:24:47 pm »
Thank you
« Last Edit: July 30, 2005, 05:52:30 pm by spystyle »
spystyle
« Reply #12 on: September 30, 2005, 09:24:35 pm »
OK, I got SortInfo to work with the new versions of MAME :)
MAME 0.141 :)
Here is the bat file :
(mame executable) -listxml > gamelist.xml
xml2info2 < gamelist.xml > gamelist.txt
So you need the file "xml2info2.exe"
example 1 :
MameUI32 -listxml > gamelist.xml
example 2 :
MAMEpp -listxml > gamelist.xml
example 3 :
MAME -listxml > gamelist.xml
example 4 :
MAME64 -listxml > gamelist.xml
So I guess we can continue to use Sortinfo forever ?
Cheers!
Craig
« Last Edit: January 11, 2012, 02:10:44 pm by spystyle »
