Author Topic: G07 Repair Question  (Read 1269 times)
jimmyjet
  • Last login:June 03, 2008, 06:39:55 am
G07 Repair Question
« on: July 13, 2004, 05:47:08 pm »
I am working through Randy Fromm's repair flowchart.  He says to check the regulated power supply at R1.  "The terminal closest to the CRT should measure +120VDC."  Using my DMM, what do I connect the leads to.  I tried the red lead to the white wire on the resistor and the black to the chassis ground.  Is this correct?  I got 0 VDC.  Please help a novice.
jimmyjet
Ken Layton
  • Guru
  • Technician
Re:G07 Repair Question
« Reply #1 on: July 13, 2004, 06:26:50 pm »
Yes, that giant white resistor gets the "+" (red) meter lead and the frame ground gets the black meter lead. If you get zero volts then the small soldered-in fuse on the monitor is blown. When that happens, that large gray filter capacitor then holds a full 135 volt dc charge with no place to go! It packs a wallup if you touch it. With power disconnected and picture tube discharged, take the monitor board out and flip it over. Touch a 60 or 100 watt ordinary house light bulb across the + and - terminals of that large capacitor. The light buld will glow bright for about 2 seconds (it does NOT damage the bulb). That discharges that cap safely so you can work on the chassis.
If that little fuse is blown then the flyback and/or the horiz out transistor are bad.
