Author Topic: ArcadeVGA M.A.M.E. Resolution Tool v1.02 Released!  (Read 3693 times)
« on: July 12, 2004, 04:29:31 pm »
Just a small release to make the prog compliant with MAME v0.84 (but retains compatibility with older versions)...
One thing to note, if you have used previous versions, you may need to delete AMRT.CFG from the installation folder (ie if it exists, delete it).
http://mamewah.mameworld.net
« Last Edit: July 12, 2004, 04:56:28 pm by Minwah »
kujina
  • Last login:November 04, 2021, 12:07:40 pm
Re:ArcadeVGA M.A.M.E. Resolution Tool v1.02 Released!
« Reply #1 on: July 12, 2004, 07:46:50 pm »
Hi
I just installed it, I could get any of the roms to appear?
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« Reply #2 on: July 12, 2004, 08:18:16 pm »
hey minwah is there a setup file or whatnot that will allow more resolutions from the arcadevga...only reason i ask this is cause i have a d9200 as well along with the arcadevga and i can get in alot more resolutions in advmame but dont like to put all that time into configuring the advmame. thanx
« Reply #3 on: July 13, 2004, 06:55:46 am »
Hi
Sorry that just doesn't make sense!  ???
« Reply #4 on: July 13, 2004, 06:56:39 am »
You can modify the ArcadeVGA.txt file if you like - just add on any extra supported resolutions...
kujina
« Reply #5 on: July 13, 2004, 07:12:36 am »
Hi
I cant get  a list of games to apear.
« Reply #6 on: July 13, 2004, 07:17:15 am »
OK, what version of MAME are you using?  If <0.84 make sure you tick the 'Legacy MAME' option.
Also, the list no longer auto-generates (because when you select your MAME exe you may not have set Legacy MAME yet).  So you need to hit View > Generate Native Res List (or whatever).
Let me know if that doesn't work...
kujina
« Reply #7 on: July 13, 2004, 07:54:54 am »
I downloaded the lastest version of mame and I still cant get it to work. There are roms in the roms folder.
kujina
« Reply #8 on: July 13, 2004, 07:59:41 am »
I got it working now, the resolution tool didn't like my folder structure which was D:\Drive (D)\mame
« Reply #9 on: July 13, 2004, 09:09:06 am »
Really?  What did you change it to?  Was it the spaces it didn't like?
kujina
« Reply #10 on: July 13, 2004, 09:17:09 am »
I just moved mame to the root of D: and it worked.
« Reply #11 on: July 13, 2004, 09:23:45 am »
OK, thanks, I'll try and fix that if I can replicate the problem...
kujina
« Reply #12 on: July 14, 2004, 07:09:43 pm »
I thought all the possible arcadevga resolutions were already included in the ArcadeVGA.txt file, or are there more?
« Reply #13 on: July 15, 2004, 04:30:16 am »
Yes you're right...I can't remember if 800x600 is in the standard ArcadeVGA.txt or not, but I think that is the only extra res. that the D9200 will do.
