Author Topic: I-PAC won't work with MAME  (Read 2917 times)
Vulas
  • Last login:July 10, 2004, 10:49:35 pm
« on: July 10, 2004, 07:06:33 pm »
All controls are wired and when I go into notepad/word and go into test mode for the I-pac all the controls register with the correct corresponding keystroke. When I go into MAME32 and start a game either the controls don't work at all or they perform the wrong function. I have reset MAME back to all it's defaults and have even installed a fresh copy and I get the same problem. I can however pick up the keyboard and it works fine.
PLEASE HELP!!!!!!
walls83
  • beer is good
Re:I-PAC won't work with MAME
« Reply #1 on: July 10, 2004, 07:35:32 pm »
have you tried using WINPAC to program the iPAC?
Vulas
« Reply #2 on: July 10, 2004, 07:37:23 pm »
Yeah I tried that and that is actually another issue I'm having, it seems like it is starting the programming process then it says "FAILED I-PAC NOT CONNECTED" or something along that basic line.
walls83
  • beer is good
« Reply #3 on: July 10, 2004, 09:47:36 pm »
you need to switch your plugs(cant remeber what they are called) on the ipac.  On the ipac there is a little black piece of plastic covering to wires that say mame.  YOu need to take the little piece of plastic of and move it to "ALT".
cut and paste link
http://www.geocities.com/walls83/ipac1.jpg
Vulas
« Reply #4 on: July 10, 2004, 10:46:25 pm »
This is one of the new ones without the MAME/ALT jumper.
walls83
  • beer is good
« Reply #5 on: July 10, 2004, 11:30:22 pm »
contact utimarc thats my only answer
reebboy
  • Last login:December 12, 2005, 01:34:53 am
  • Now its time for some serious insanity!!!
« Reply #6 on: July 19, 2004, 08:31:10 pm »
I had the same problem with my I-pac 4. I noticed that if you leave the keyboard connected to the I-pac and not re-plug it back into your computer none of the controls will work right.
Dude!!! Where's my game.....
