Author Topic: Arcade VGA cable and ground?  (Read 2245 times)
vartech
  • Last login:March 20, 2013, 03:38:17 pm
  • The Great Swordsman Hiko
« on: July 08, 2004, 11:50:57 am »
I have the Arcade VGA cable and I am trying to wire it using the cable from ultimarc on a Wells-Gardner 25k7193 monitor.  the question is the cable has G R B H V and a bunch of cables wrapped together with a I is this ground? and if so were do I ground it?  also the picture scrolls vertically.  I have changed the pots on the board and finally had to connect the H and V together.  will a video amp take care of allowing me to solve the scrolling and seperate the H and V so I can add a light gun?   ???
Please help I have three boys who are howding me to play the games i talked about when I was an arcade adict.
proview
  • Last login:July 11, 2007, 02:47:19 am
Re:Arcade VGA cable and ground?
« Reply #1 on: July 08, 2004, 04:07:52 pm »
Hello vartech.
I'm not familiar with that cable and could not see a description of it on the Ultimarc site but for the connection you should take a look here .. http://link.mywwwserver.com/~jstookey/arcade/WG_25k7191/
That should also answer the question about the light guns (seperate H & V).
Regards to all,
John
vartech
« Reply #2 on: July 08, 2004, 04:51:46 pm »
I will look at the cables on my monitor it had five cables of a harness that I assumed were R G B Vert and Horz.  Now I wonder if they were R G B Horz and ground.  I will have to double check that.  the cable does not match the discription from Ultimarc because they say it is labeled ground but Mine has an I and it is made up of mutlple cables.  I will check and reply when possible but I am gone for three weeks vacation.  I hope this works my kids are dying to play
vartech
« Reply #3 on: July 09, 2004, 08:51:42 am »
Proview thanks for the link it was exactlly what I was looking for I found out wht aI thought was V was Ground so I ground that and now just have to connect a wire for the Vert.
Paladin
  • Mmmm llamaburgers!
« Reply #4 on: July 09, 2004, 03:28:02 pm »
No, no, no...
The bunch of wires wired together are the ground.  The lable is not the letter "I", it is a "-" dash symbol.
The H and V are horizontal and vertical synch.  If your monitor is a composite synch, then you combine the V and H wires together and attach them to the monitor.
Check this link:
http://www.ultimarc.com/avgainst.html
To quote the web page:
R, G, B = colours
H = horizontal sync. H and V sync can normally be connected together for most monitors to produce composite sync.
V = vertical sync
- = ground
+ = 5 volts. This connection must be insulated if not used.
A side note, I recently purchased my cable and there was no "+" wire.  This was fine because I didn't need it anyway.
vartech
« Reply #5 on: July 09, 2004, 03:41:20 pm »
I figured the -  was the ground and it uses composite sync but found out here that I can seperate the V and H
The only issue I have now is the vert is scrolling when I switch from mamewah to mame to xp.  I can adjust to stop it but it is still a pain.
