Author Topic: mounting original Ikari rotary stick in wood panel?  (Read 1067 times)
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« on: July 08, 2004, 11:16:52 am »
looking at pics from video connect and ebay, looks like this stick is made for a thin metal control panel.  Has anyone successfully mounted it in a 3/4" wood panel, and how?
was thinking either a mouting plate like from Oscar, or route the top out slightly and mount it on top of control panel.
thanks,
mattv
  • Last login:June 10, 2022, 06:33:25 am
Re:mounting original Ikari rotary stick in wood panel?
« Reply #1 on: July 08, 2004, 05:00:07 pm »
if you don't mind hacking a honking great hole in your control panel then a mounting plate is the way to go.  You can make your own with a hacksaw and a holesaw if you don't want to pay for one, but to be honest they are so cheap you might as well just pay the $$ and save some time.
By the sounds of things you have access to a router, if you want the mounting plate to sit flush with the rest of the control panel you can route a tiny bit off the top of your CP to drop it in.
rdagger
« Reply #2 on: July 08, 2004, 06:28:41 pm »
I mounted my LS30's on top of the CP.  I cut a hole in the CP just large enough for the joystick body.  Then I routed out the top of the cp to allow the joystick frame to sit flush with the top of the CP.  I covered it with Lexan.  I then used screw posts to secure the joysticks.  Here are some low quality pics.  If there is any interest I could take a close up.
« Last Edit: July 08, 2004, 06:55:40 pm by rdagger »
