Author Topic: OSB Plywood  (Read 6475 times)
JAMMA Guy
  • Last login:June 18, 2004, 01:14:07 am
  • PCB's Are Better!
OSB Plywood
« on: July 06, 2004, 04:59:26 pm »
Has anyone here built a cabinet out of OSB.
I'm having a terrible time getting a hold of MDF.  Most of the idiots in my area have never even hear of MDF and the folks that even know what I'm talking about don't have a supplier.
I have one guy that can order me 3/4" MDO but I think he quoted me a price that insane (I'm thinking he said $50 per 4'x8' sheet ... I'll have to check with him again in person to make sure.).
The nearest place I can get a hold of 3/4" MDF is a Lowes 50 miles away  :-\
Since AC Plywood has almost doubled in price since last year I'm definitely not going that route this year. ($40 or more for a 4'x8' sheet)
Just wondering if anyone has used OSB and what there experience was with it (ugly stuff ... apparently strong that 3/4" AC plywood but at the cost of CDX).
It's going to be laminated except for the 1/2" recesses ... I'll just paint them a glossy black.
Thanks for all replies in advance :)
« Last Edit: July 06, 2004, 05:03:38 pm by JAMMA Guy »
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re:OSB Plywood
« Reply #1 on: July 06, 2004, 07:43:18 pm »
See if they have 1/8" hardboard, then take it to them and show them and then say "Now I need this stuff, but 3/4" thick".  That'll tell you if they're regular idiots, or the kind that should have helmets and a warning sign. ;D
Where are you, BTW?  I'm guessing somewhere in North America, since you spoke of a Lowe's being near you.  That'll help.
froggerman
  • Last login:March 01, 2015, 03:23:14 am
  • You want how many buttons?!
Re:OSB Plywood
« Reply #2 on: July 06, 2004, 08:07:58 pm »
I am not sure about the US but in Canada OSB (Oriented Strand Board) and Particle board are completly different products. OSB is usually made from large pieces, chips, of wood where Particle board is made from sawdust. OSB is sometimes used in commercial arcade cabinets for bottom panels and internal shelves, just areas where it will not show.
MDO is also much different than MDF. It is normally used for signs. It has one side covered, or is it both, and is very smooth but also very expensive.
JAMMA Guy
  • PCB's Are Better!
Re:OSB Plywood
« Reply #3 on: July 07, 2004, 06:44:48 am »
They have 3/4" OSB ($19 per 4'x8' sheet)
Yes ... it's made from big ol' wood chips unlike particle board.
I'm located in West Virginia (near Gallipolis, OH) ... the worst place you could possibly live if you want MDF .... lol  ;D
I was mainly concerned with chipout ... how well it excepted laminate ... and if it was easy to paint.
MDO is veneer core hardwood plywood overlaid with a pressed fiber material (MDF surface ... so both sides are smooth) ... best of both worlds.
Spystyle ... viewing your site ... you used particle board ... not OSB.
Here's a link that shows the difference between MDF, Particle Board, and OSB : http://www.lowes.com/lkn?action=howTo&p=Build/OSBMDFPart.html&rn=RightNavFiles/rightNavHowTo
« Last Edit: July 07, 2004, 06:46:08 am by JAMMA Guy »
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
Re:OSB Plywood
« Reply #4 on: July 07, 2004, 09:45:18 am »
You really DON'T want OSB. I can't even fathom how on earth you would ever make it a finishable surface, and if it so much as thinks about getting wet it's gonna flake all over the place.
For $60 - you can get OSB. For $120 - you can get finish grade plywood. Yes, it's twice as much, but $120 for all the wood you need for the entire cabinet and control panel, it's not that bad. Most people spend more than that on artwork.
Hell, most people spend that much on a trackball/spinner setup.
BYOAC users get 5% off with coupon code byoac5
Wade
  • Last login:March 08, 2026, 03:31:11 pm
  • 80's Child
    • Wade's Gameroom
Re:OSB Plywood
« Reply #5 on: July 12, 2004, 12:55:05 pm »
OSB is about the worst thing you could use, don't even try it.  MDO would be great, or MDF.  I had no problem finding MDF at both Home Depot as well as the local lumber company (Evans), you should be able to find it pretty easily.
I'm in Charleston, WV, check out my website and let me know if you want to get together to do some gaming sometime, or just shoot the breeze.
http://webpages.charter.net/wadelanham/arcade/
Wade
