Author Topic: exiting out of PJ64 and VisualBoy Advance Freezes Mamewah!  (Read 2164 times)
walls83
  • beer is good
« on: July 06, 2004, 04:13:30 am »
Im using both emulators from screen archives that let you escape with the exit button.  I thought maybe the resulution was the problem but I changed them to the same res as my screen but still no luck.  When I hit the escape key for them the screen goes black and you can still hear them running in the background.  So I have to hit ctrl alt del to exit them.  when I go into ctrl alt del it says mamewah not responding, but as soon as I end task on the emulator everything works with mamewah again.  Any suggestions on what is going on with these two emulators?  SORRY TO POST THIS ITS PROLLY CAME UP 100 TIMES.  THIS BOARD NEEDS A SEARCH TOOL.  thanks again.
Re:exiting out of PJ64 and VisualBoy Advance Freezes Mamewah!
« Reply #1 on: July 06, 2004, 05:22:19 am »
The problem here is PJ64 not closing.  MAMEWAH won't crash, it is just waiting for PJ64 to close, and so it appears to be not responding.
Does PJ64 exit properly from a commandline?
walls83
  • beer is good
« Reply #2 on: July 06, 2004, 02:56:11 pm »
Ya they exit fine from the command line its like my Computer is half way closing the emulator and half way bringing up mamewah.  I dont know..
walls83
  • beer is good
« Reply #3 on: July 06, 2004, 03:36:23 pm »
I think its the emulator. Could someone post there PJ64 specs so I can change mine? thanks
« Reply #4 on: July 06, 2004, 05:57:25 pm »
Maybe try setting Show DOS Box to Yes (or 1 if you edit the CFG files).
