Author Topic: New I-PAC VE  (Read 2973 times)
Alucard90
  • Last login:June 26, 2011, 05:57:10 pm
New I-PAC VE
« on: July 04, 2004, 11:39:40 am »
This might be old news but ultimarc is now selling a VE edition of the I-PAC2 that is only USB but 4 more inputs. but stores codeset in RAM and does not work in DOS. Seems like a fairly good deal, free shipping.. more info here: http://www.ultimarc.com/ipacve.html
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
Re: New I-PAC VE
« Reply #1 on: March 14, 2005, 02:28:18 pm »
Has anyone used this encoder yet?  Does it work out okay?
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
Re: New I-PAC VE
« Reply #2 on: March 14, 2005, 02:33:32 pm »
Works just fine for me. It is probably a bit more fidgety if you want to make input changes because of the RAM storage, but there are published work-arounds for that. I use it in a short cab with basic controls that runs MAME only, so little need for other than standard inputs.
Cab Specs:
AMD xp1600
Win98
Mamewah .97
DOS MAME .83
Kobex
  • Last login:December 23, 2016, 06:59:30 am
Re: New I-PAC VE
« Reply #3 on: March 14, 2005, 02:34:03 pm »
I have one and it works fine for me.  I just have my "default" code set loaded when windows boots up, since it doesn't store them when powered off.  The extra buttons came in handy for admin functions.
NoBonus
Re: New I-PAC VE
« Reply #4 on: March 14, 2005, 02:41:01 pm »
When considering value and function, this is top of the heap.  You can still use your keyboard (unlike the 19.99 KeyWhiz Eco), no soldering (unlike the KeyWhiz Eco), and NO SHIPPING (unlike the KeyWhiz Eco).  I may have made my choice...  any gripes with this other than the custom keyboard layout and lack of DOS support?
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
Re: New I-PAC VE
« Reply #5 on: March 14, 2005, 03:21:36 pm »
Hasn't this encoder been out for quite a while now?
first off your and idiot
ripzone
  • Last login:February 23, 2006, 02:28:01 pm
  • Pac-Mini coming soon...
    • RiP's M.A.M.E. Arcade Cabinet
Re: New I-PAC VE
« Reply #6 on: March 14, 2005, 03:25:25 pm »
It has been posted on 04 July 2004.
Vicious
Re: New I-PAC VE
« Reply #7 on: March 14, 2005, 03:27:54 pm »
Did you have a bad experience with the KeyWiz or something?  Everything seems to make a point against the KeyWiz.
Unless the shipping is $15 dollars then there is no comparison in price.  I've been doing it for over 13 years so it may be easy to me, but soldering is not hard.  And if it's going to be in a dedicated cab, a keyboard is not a necessity.
One thing you forget about the 'free shipping' is that it is sent with no tracking.  So if it gets lost, you're out $35 with no encoder.
NoBonus
Re: New I-PAC VE
« Reply #8 on: March 14, 2005, 04:05:37 pm »
Has anyone had any experience with the KeyWhiz "GP-Whiz"?  Is it the same as the Key-Whiz, just with USB instead of keyboard interface?  Also, I am familiar with soldering, is soldering to the Key-Whiz much trouble?
PrizLucky
  • Last login:April 28, 2010, 09:42:32 am
  • It's good to be lucky
    • My arcade blog
Re: New I-PAC VE
« Reply #9 on: March 14, 2005, 04:23:31 pm »
If you're looking to avoid the soldering, there's the No-Solder version of the KeyWiz Eco (for $3 more).
It's a piece of cake, I just wired up my very first control panel with a KeyWiz Eco (no-solder version) this weekend.. very simple to use.
NoBonus
Re: New I-PAC VE
« Reply #10 on: March 14, 2005, 04:27:53 pm »
Did you just cut and strip the required connector then solder/connect the wires together?
PrizLucky
    • My arcade blog
Re: New I-PAC VE
« Reply #11 on: March 14, 2005, 04:33:50 pm »
Yep, stripped out an IDE cable, and connected the wires.. (this is a temporary/test CP, so for now the connections are just taped with electrical tape).   Also, I'm thinking of trying to use one of those round IDE cables to avoid the shredding of a IDE Ribbon cable the next time around... :)
