Author Topic: coin-up/insert coin button  (Read 3469 times)
Nefesis
  • Last login:August 25, 2007, 11:28:22 am
  • psst... star wars... it's the greatest!!!
« on: July 02, 2004, 01:46:21 pm »
why do you need a coin-up and an insert coin button? couldn't you just use one for both? and also, for those of you using an ipac, whgat keyboard button do you have your coin-up/insert coin button hooked up to?
Onji
  • Last login:December 20, 2024, 05:31:43 pm
Re:coin-up/insert coin button
« Reply #1 on: July 02, 2004, 02:01:01 pm »
I believe they are one in the same. You only need one button.
For question 2, if your using the default mame config, player 1 coin insert is the number 5 on your keyboard.
Keep in mind, if you plan on doing a 2-4 player cab, there are several games that require you to insert the coin for that specific player. ie. gauntlet, simpsons, tmnt etc etc. If you are concerned about this, then you'll need an insert coin button for each player. If not, one will suffice. If i'm not mistaken (which is completely possible that i am) the default insert coin keyboard buttons for mame is:
Player1 = 5
Player2 = 6
Player3 = 7
Player4 = 8
« Last Edit: July 02, 2004, 02:02:47 pm by Onji »
Nefesis
« Reply #2 on: July 02, 2004, 05:10:15 pm »
ok. in the cd that comes with the book project arcade i think it has templates for both coinup and insert coin. thank you.
