Author Topic: Dreamcast  (Read 5272 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
Dreamcast
« on: July 02, 2004, 12:00:41 am »
I have a dusty dreamcast hooked to my tv so i was thinkin bout throwin it in my cab for games like blitz, showtime, and rush.
I was wonderin who else has a dreamcast in there cabs, what games are good, and what controllers u hacked.
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Dreamcast
« Reply #1 on: July 02, 2004, 12:04:08 am »
check out te console forum, where I am going to move this...
TalkingOctopus
    • My Arcade
Re:Dreamcast
« Reply #2 on: July 02, 2004, 12:16:43 am »
I have one in my cab and it is great.  I highly recommend it.  I play a lot of marvel vs capcom 2, soul caliber, capcom vs snk 2, Guilty Gear X, and Ikaruga on my DC.  I hacked the normal pads, but just about any pad is hackable.
Here are some other posts that may be useful:
http://www.arcadecontrols.org/yabbse/index.php?board=15;action=display;threadid=18783 - DC is it worth it?
http://www.arcadecontrols.org/yabbse/index.php?board=15;action=display;threadid=19067 - DC Game listing
Links:
http://members.cox.net/joysticks/ - DC hacking tutorial
the3eyedblindman
Re:Dreamcast
« Reply #3 on: July 02, 2004, 12:25:26 am »
Is the dreamcast sega controller really that hard to hack, how did u do it, i heard it was hard
TalkingOctopus
    • My Arcade
Re:Dreamcast
« Reply #4 on: July 02, 2004, 12:44:31 am »
I did not have a hard time doing the hack.  The first 2 controllers I did worked.  I pretty much followed the guide that is in the link above.
Here is a marked up photo of the controller PCB:
http://members.cox.net/joysticks/joystick_images/dc_segapad/Sega_Pad_Detail.gif
One smart forum member observed that you do not have to scrap off the button contacts like he did in the tutorial.  Instead, follow the button contact to the corresponding hole and attach the wire there.  Also, make sure you use flux when you solder (follow the soldering guide from the tutorial).
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
Re:Dreamcast
« Reply #5 on: July 02, 2004, 08:31:20 am »
Awwww, you called me smart!  *Blush*  Actually, the holes on the Sega controllers aren't quite all the way through, you have to open them up with a Pin Vise (Get one from your local hobby store) and scrape the covering away from the circle around the hole (Very easy to do with a little bit of sandpaper).
If no one feeds the trolls, we're just going to keep eating your goats.
PinoyArcade
  • Last login:June 09, 2004, 11:21:28 am
Re:Dreamcast
« Reply #6 on: July 03, 2004, 12:59:55 pm »
Hi guys!
Im planning to set-up a cab (for business purposes) using DC inside but I really cant figure out what to do to hack the start sequence to make it 'arcade-like' ( just a coin would start a game ). Ill be using marvel vs capcom 2 but the strat sequence will move you to game options, etc. etc. Is there a way to by-pass this and a single start ( coin ) will eventually lead to a single full game?
thanks
abrannan
Re:Dreamcast
« Reply #7 on: July 03, 2004, 05:29:45 pm »
Hi guys!
thanks
There's a device that will do this (allow you to put a DC in a cab).  Cearch this forum for more info.  They come up on Ebay every now and then, but they're fairly pricey.
the3eyedblindman
Re:Dreamcast
« Reply #8 on: July 05, 2004, 12:34:12 am »
how deep do u have to scrape to hack it? i tried to hack a ps controller once, a sony one that had the black stuff, and i almost scraped strsaght through,  i dont know when to stop
abrannan
Re:Dreamcast
« Reply #9 on: July 05, 2004, 09:46:28 am »
Not very deep, it's just a small layer of plastic to hide the metallic trace underneath.  Stop whe you see a gold metallic color coming through.
unicron
  • Last login:September 26, 2005, 05:44:10 pm
    • My arcades
Re:Dreamcast
« Reply #10 on: August 07, 2004, 08:15:26 am »
Hi guys!
thanks
Don't ---smurfing--- charge people to play DC.
PinoyArcade
Re:Dreamcast
« Reply #11 on: August 09, 2004, 10:37:47 pm »
sorry dude...but its for business
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Dreamcast
« Reply #12 on: August 10, 2004, 12:31:12 am »
If this is a real business then you should know that Dreamcast games are licensed for home use only and not for commercial use.  You should look into the Naomi system if you want commercial use Sega games (you can find them on ebay).
unicron
    • My arcades
Re:Dreamcast
« Reply #13 on: August 10, 2004, 06:24:12 pm »
No, I do business, and I know people who do business. Charging people to play DC is not doing business, it's you being a worthless punk. Arcade games are so cheap, that if you actually plan on making any money it's COMPLETELY retarded to go the DC route.
The only way the DC taking quarters route would work is if you wheren't going to make much money AT ALL. In which case there's no point to shuck the few dollars out of ppl.
In short, you aren't doing business, you are just not thinking.
Charging people to play DC is a ghetto scam that won't save you ---steaming pile of meadow muffin---, it'll just keep you from making your proper dough, fool.
PinoyArcade
Re:Dreamcast
« Reply #14 on: August 11, 2004, 01:55:53 am »
you are entitled to your own opinion, fool.  Youre a fool after making such comments without knowing first what my business is all about. I customized cabs on a per order basis here in the Philippines where I use standard consoles rather than jamma and these are all used for personal use by console owners who opt to play it 'arcade style' . I own a woodworking shop/carpentry shop by the way and I try to package things up by making some electronics/electrical works for my arcade loving customers.
where is the ghetto scam here???
If you have nothing good to say...please shut your mouth or i mean... stay away from that computer keyboards...your fingers might be a faster thinker than you brain.
Dave_K.
    • Arcade Fever
Re:Dreamcast
« Reply #15 on: August 11, 2004, 08:33:40 pm »
The device which makes the dreamcast "coin'able" is a DC-to-Jamma interface...so if you say you don't want to go jamma (or don't have a jamma wired cab to begin with), then I don't think there is any alternative other then wiring the start button to the coin mech.
As for the legality of selling the DC enabled cabs,  I don't see anything wrong there.  But then again, there is nothing from stopping your customers from simply putting them in public places to earn real money.  Oh well.
DougHillman
  • Last login:September 13, 2004, 07:39:18 pm
Re:Dreamcast
« Reply #16 on: August 12, 2004, 02:18:33 pm »
Maybe you oughta take a helping of your own advice.
Someone who's only posted a handful of times talking about using their cabinets for business?
Of course the  immediate reaction is that it's going to be put on-site to generate income.  You didn't do anything to refute that belief with your first reply. "Sorry dude, it's for business."  And honestly, your explination isn't really totally convincing.  Nor your heated response.
If you can't be a good example at least try to be a horrible reminder.
PinoyArcade
Re:Dreamcast
« Reply #17 on: August 14, 2004, 12:45:21 am »
So whats your point anyway?
unicron
    • My arcades
Re:Dreamcast
« Reply #18 on: August 18, 2004, 04:47:59 am »
That your scam is ghetto, don't charge for DC!
*tee hee*
and I'll say no more!
abrannan
Re:Dreamcast
« Reply #19 on: August 18, 2004, 08:40:27 am »
I believe his point was that you could have saved a lot of people a lot of typing time if you'd just explained your business model up front, rather than tossing off a flippant "It's for business, dude", as you did.
