Author Topic: Plywood Issues..  (Read 1731 times)
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
Plywood Issues..
« on: June 26, 2004, 07:42:51 am »
Hello there.
I have a little problem with the base on the right side.
the plywood is starting to come apart...aarrggghhh.
The plywood is in Perfect condition for a varnish-type finish so i don't want to mess it up with screws etc.
Whats the best way to re-join the sheets ?   ???
EDIT..  The ply is comming apart.
« Last Edit: June 26, 2004, 01:25:20 pm by Acids »
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re:Plywood Issues..
« Reply #1 on: June 26, 2004, 10:51:28 am »
Do you mean that the layers of the plywood sheet are starting to separate?  Or are two pieces of ply pulling away from each other?
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
Re:Plywood Issues..
« Reply #2 on: June 26, 2004, 11:22:47 am »
Get some glue behind the part that is coming away for the plywood and clamp it until dry. If you don't want to clamp it put contact glue onto both sides and wait 20 minutes then press it together and it will hold.
Gary
Acids
Re:Plywood Issues..
« Reply #3 on: June 26, 2004, 01:26:31 pm »
Gary
Good Idea, the trick will be to get the gue in there without opening it apart any further   :-\
