Author Topic: Optipac/trackball help?  (Read 1177 times)
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« on: June 25, 2004, 08:29:11 am »
Got my mock control panel setup, and I managed to get everything working except up/down on the trackball.
I don't have a multimeter. Any ideas on what I can check? I double checked the wiring, pulled out and re-set the plug on the trackball to make sure it was in good. Made sure everything is spinning correctly...
BYOAC users get 5% off with coupon code byoac5
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
Re:Optipac/trackball help?
« Reply #1 on: June 25, 2004, 03:27:42 pm »
One thing you could try is switch the up/down wires with the left/right at the OptiPac (leave alone at the TB).
- If it will now move up/down when you move the TB left/right then I would assume there might be something wrong on the TB or wiring end
- if it will still not go up/down, but will still only go left/right then I would assume the issue is at the OptiPac.
As a quick check I might take some new wires and temporarily rewire the up/down and ground wires to make sure the issue isn't just a bad wire.
:) Rotate or die! :)
Sylentwulf
« Reply #2 on: June 26, 2004, 02:27:53 pm »
Amazing how much one bad crimp can take an hour of playing, swapping, yanking and soldering...
But, it works, so I don't care now  ;D
