Author Topic: Smartstrip Question  (Read 1352 times)
Knievel
    • Knievel Kustoms
Smartstrip Question
« on: June 24, 2004, 11:19:44 am »
Thinking about adding one of these to my cab but I never really shut my cpu down.
Would I have to actually turn the cpu OFF to get the rest of my stuff (marquee light, speakers, etc) to turn off or would the computer goin into 'sleep mode' be enough to trigger it?
If not can anyone suggest the best way to have the whole cab go into this 'sleep mode'?
Tailgunner
Re:Smartstrip Question
« Reply #1 on: June 24, 2004, 09:07:50 pm »
No reason you'd have to shut the computer down if you don't want to. Just plug something else into the control outlet.
I'm not sure if the Smartstrip has any outlets that aren't controlled, if not you'll need a seperate outlet to plug your computer into.
TalkingOctopus
    • My Arcade
« Reply #2 on: June 24, 2004, 09:43:07 pm »
Just to let you know, there are several outlets that are not controlled on the smartstrip.
Goz
  • KOTA
« Reply #3 on: June 24, 2004, 09:43:46 pm »
The smart strip has 3 constant hot plugs (colored red).
-Goz
SpamMe
  • Last login:July 01, 2006, 03:19:58 am
  • .creature of bad habit.
    • Mame cabinet blog
« Reply #4 on: June 24, 2004, 10:08:38 pm »
I know that standby and hibernate are enough to shut down the other components...
Knievel
    • Knievel Kustoms
« Reply #5 on: June 25, 2004, 12:20:38 am »
Thanks for the replies guys.
Not sure if I made the question clear or not but SpamMe gave me the answer, Thanks :)
