Author Topic: What size pc monitor will fit in a 19" frame?  (Read 3034 times)
Keith O
  • Last login:March 15, 2006, 04:55:42 pm
  • Get off me cheese!
« on: August 10, 2002, 09:55:28 pm »
It appears to me that a 19" tv and a 19" pc monitor are not the same size (please correct me if I'm wrong). I have a metal frame for a 19" arcade monitor and was wondering what size PC monitor would nicely mount into that frame. Has anyone tried this?
SNAAAKE
  • -Banned-
Re:What size pc monitor will fit in a 19" frame?
« Reply #1 on: August 11, 2002, 01:55:01 am »
likely you will have problem..because many monitor has different sizes.....you can always make a wood frame if things dont work out. when i converted  sf machine with 19" frames..i had trouble(nightmare) fitting 19" eygo monitor..even though the frame and the monitor is same size..i had to make the frames all over again...use plywood for safety..ply is like bullet proof and its good for monitor..incase your metal bracets dont fit.
