Author Topic: Casters and MDF -- Which screws do I need? (re: Project Arcade Book)  (Read 6351 times)
sofakng
  • Last login:February 18, 2021, 04:19:21 pm
I'm using the Project Arcade book but it's vague on which screws I need to connect my casters (3 inch depth) to my MDF board (3/4" board).
The book says:
"You'll be using flathead machine screws and nuts to fasten the casters to the cabinet base."
So... I'm sending somebody to Home Depot for me tomorrow but I need to tell them what to get.
Do I need a certain size "flathead machine screw"?  Do I need a certain size nut?
I'm using size #8 screws for everything else in case that matters...
crashwg
Re:Casters and MDF -- Which screws do I need? (re: Project Arcade Book)
« Reply #1 on: June 22, 2004, 11:42:33 pm »
Do you have the casters already?  If so, send those to HD. Along with the knowledge of that they're going to be attached to 3/4" MDF, that should be all that is needed to get the appropriate size hardware!
« Last Edit: June 23, 2004, 01:24:52 am by crashwg »
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
« Reply #2 on: June 23, 2004, 12:18:48 am »
perhaps bolt may have been a better word than screw, if you want to something that connects with a nut and washers.  Just get the biggest size that will fit through the hole in your caster.  I guess a screw would work but I think for casters, taking the weight of the cabinet, a bolt would be better.  Larger than #8 though.  This type of part, doesn't really matter exactly what you use, as long as it ends up being sturdy.
Apollo
    • Eight Bells
« Reply #3 on: June 23, 2004, 02:10:09 am »
Yup you should really use bolts, I used wood screws but only because I had to. I used 3" wood screws so they shoud have a good chance of staying put and I was screwing in to ply. I would suggest bolts.
ErikRuud
  • Last login:March 23, 2026, 07:42:27 pm
« Reply #4 on: June 23, 2004, 11:23:08 am »
Basically, a machine screw is a bolt!
I think the term "Machine Screw" is used for bolts with slotted or phillips heads on them instead of the usual hex head.
American Laser Games Wrapper
O2em Rom Utility
Ghoward
  • Last login:July 09, 2021, 10:45:22 pm
  • Mame rocks!!
« Reply #5 on: June 23, 2004, 11:25:31 am »
I have to agree use bolts that's what I have always done on my cabs.
Gary
