Author Topic: Australians: where to buy a TV for my cab?  (Read 1869 times)
captainpotato
  • Last login:November 11, 2016, 06:10:59 am
  • I'm a tapir!
    • Tapir Design
« on: June 18, 2004, 10:39:21 am »
Fellow aussies,
Does anyone have any idea where I can get a decent new TV for my cab - preferably in Adelaide? It needs to meet these specs:
- 21"-23" screen (to fit horizontally in a Pac-Man cab, which is 23" wide internally);
- SCART input (if not, then S-VHS);
- No speakers on the side (so it's not too wide);
- Not ridiculously expensive.
I've had a look around a few shops, but cannot find any with SCART or S-VHS in the size range I want, let alone the rest :P Any ideas are much appreciated.
Ekstreme
  • Last login:March 03, 2014, 06:31:11 pm
Re:Australians: where to buy a TV for my cab?
« Reply #1 on: June 18, 2004, 11:52:58 pm »
I'm about the face the same Dilema, but i was thinking maybe cash converters as most new stuff is flat screen, with side speakers etc
wboy
  • Last login:November 03, 2005, 05:09:19 pm
« Reply #2 on: June 19, 2004, 09:09:52 pm »
If you want a TV with scart adapter support, your best bet is to go to Audio & Video specialists that carry/import European model TVs such as Loewe, Grundig and the like...
Several exist in Melbourne, not sure about Adelaide though.
Being a high quality european TV, there is a quite hefty price attached in most cases.
From the sounds of things you plan to use a ArcadeVGA?
If so, you are better approaching arcade retailers in your local area and getting a proper arcade monitor IMO.
The Horz/Vert/Size etc controls to adjust the monitor will be easily accessable making it alot less of a head ache to adjust when required!
Probably work out cheaper too!
captainpotato
  • I'm a tapir!
    • Tapir Design
« Reply #3 on: June 20, 2004, 04:09:01 am »
Hi Wonderboy,
Thanks for the advice. I had been planning to get a standard PC video card (ATI most likely) and use that to drive the TV.
I assumed that the TV option would be cheaper, but from what you are saying, that may not be the case :P I know a guy who runs an arcade machine business, so I might have to ask him.
Ekstreme: that thought occurred to me as well, but I'd prefer new if possible, but if not, then so be it.
wboy
« Reply #4 on: June 20, 2004, 09:00:13 am »
Arcade monitor is the only way to go in my opinion (and you won't regret it).
If that was not an option, I'd probably use a PC monitor over a TV from my own experience in messing with video card TV outs and their limitations.
captainpotato
  • I'm a tapir!
    • Tapir Design
« Reply #5 on: June 20, 2004, 10:29:16 am »
Okay, sounds that it might be the way to go.
Time to start a new thread along the same lines, but for arcade monitors :)
RetroBorg
  • Last login:June 10, 2026, 09:58:19 pm
« Reply #6 on: June 22, 2004, 09:20:28 am »
captainpotato,
I picked up a 21 inch computer monitor for $170 at MGS auctions on Torrens Road, perhaps a computer monitor might be the go.
WWW: http://www.mgs.net.au/
captainpotato
  • I'm a tapir!
    • Tapir Design
« Reply #7 on: June 22, 2004, 09:29:41 am »
Retroborg,
I imagine that an older monitor is probably is a little blurry anyway, isn't it - assuming that it is actually older? I've got an old 19" monitor that has lost colour contrast, but it's not so old, so it's just pale and too crisp for a cabinet.
At least the next MGS auction doesn't have any large monitors, seeing that I cannot make it ;)
