Author Topic: Can you change the screen size in Mamewah?  (Read 1546 times)
GGKoul
  • Cheesecake Apprentice
« on: June 17, 2004, 04:21:21 pm »
Having been along time MAME32 user for the past couple of years.  I've decided to switch to MAMEWAH.
Question, in MAME32, your able to change the "Aspect Ratio" from 4:3 to a larger number.  I've been using 23:21 in MAME32 and it widens the image so it looks more fuller on my 27" TV.
Just wondering if your able to change the 4:3 in MAMEWAH?  As I can't seem to be able to change it.
-GGKoul
Re:Can you change the screen size in Mamewah?
« Reply #1 on: June 17, 2004, 08:16:23 pm »
I guess you can change this in mame.ini, create this by doing 'mame -cc' at a commandline.   Generally this is where you set stuff which youd've set in a menu in MAME32.
GGKoul
« Reply #2 on: June 21, 2004, 12:26:05 am »
How would I do this?
« Reply #3 on: June 21, 2004, 05:55:08 am »
1) Open a commandprompt
2) Navigate to your mame folder, eg:
c:
cd\mame
3) Type 'mame -cc'
mame.ini will now be sitting in your MAME folder - edit it with notepad or similar.
GGKoul
« Reply #4 on: June 21, 2004, 08:52:32 am »
Prefect!!  Thanks!!
