Author Topic: would this setup work?  (Read 1727 times)
apu95
  • Last login:August 04, 2006, 09:23:14 am
« on: June 14, 2004, 04:06:42 pm »
im considering building a machine as a project for my summer break. i got the ok from the old folks :p so i just have to get the pieces together now.
im thinking of having it two player wish 6 buttons each, plus a 1 and 2 player start button.  i wanna have a keyboard as well as the joysticks at the same time, so im not sure which would be the better way to go.
would it be better to use a USB keyboard and use the keyboard port for the joysticks or just use the keyboard port for the joysticks and keyboard using a splitter?
thx!
Apu
AlanS17
    • AlanS17
Re:would this setup work?
« Reply #1 on: June 14, 2004, 04:12:58 pm »
Get a PS/2 keyboard encoder (for the controls) with a USB keyboard.
apu95
« Reply #2 on: June 14, 2004, 04:16:13 pm »
:) thx
question, tho. if im gonna be using both the ps2 keyboard input as well as a usb input, wont windows pose a problem for that since im sending keyboard "signals" from both usb and ps/2?
thx again!
kevin
  • Last login:October 24, 2004, 08:45:38 pm
« Reply #3 on: June 14, 2004, 04:18:06 pm »
The IPAC also has a keyboard pass-through on it, so if you go that route you can plug a keyboard into the IPAC, and the IPAC into your ps2 port.
-Kevin
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: June 14, 2004, 04:25:40 pm »
AFAIK, no it won't.
AlanS17
    • AlanS17
« Reply #5 on: June 14, 2004, 04:25:55 pm »
:) thx
thx again!
There shouldn't be any problem using the 2 in conjunction. However, kevin brings up a good point. All Ultimarc encoders have a pass-through port.
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #6 on: June 14, 2004, 04:34:20 pm »
having two keyboards won't cause a problem using windows.  The only possible thing I could think of is hitting the same "key" on both the arcade controls and keyboard, but I would imagine it would either just press the key or not register a key at all.  That wouldnt really matter though, as I can't think of a reason you would have your keyboard out at the same time you were  using your joystick/buttons.
The same would go for mice.  You can plug in a PS2 and usb mouse, or 2 usb mice, and they would just control the same cursor, with the only problems occuring when you try to move both mice at the same time.
first off your and idiot
apu95
« Reply #7 on: June 14, 2004, 04:56:17 pm »
thanks for all the replies :)
as for buttons, which are your preferred choice? i found a very good distributor here in canada (in toronto) which can provide me with any button, but im not sure which type to choose.
thx!
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: June 14, 2004, 05:34:35 pm »
thx!
From Happ - Avoid the vertical (Ultimates).  The Horizontal microswitch (concave) are mainly preferred.  Some people like the convex Competition buttons for fighters.
Apart from Happ, it's more a question of who made the microswitches.
