Author Topic: List of video cards that work with DOS/Windows with Advmame(15Khz)  (Read 1162 times)
menace
These two lists are cards that have been proven to work with Dos/Windows in advmame (and therefore can run an arcade monitor WITH THE PROPER SETUP/SOFTWARE).  This links directly to the advmame project site.
first the dos:
http://advancemame.sourceforge.net/doc-carddos.html
then windows:
http://advancemame.sourceforge.net/doc-cardwin.html
I take no responsibility for the accuracy of this information but thought I would provide it to those who couldn't find it.
Antix
  • Last login:July 02, 2018, 11:06:06 pm
  • Burp!?
Re:List of video cards that work with DOS/Windows with Advmame(15Khz)
« Reply #1 on: June 13, 2004, 10:14:46 pm »
Only problem with the windows list is that it starts off with....
1 SVGAWIN
The `svgawin' driver is a subset of the Linux SVGALIB library.
This driver is experimental. At present it's only tested on Windows 2000 with a GeForce 2 board. It may not work will all the other boards.
If you read their other docs it says that they think it will work because it works in DOS, but cant confirm this.
