Author Topic: S3 Virge-VX (4MB) or ATI AIW Pro (16MB)?  (Read 1846 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: June 11, 2004, 10:33:06 pm »
The obvious answer is the ATI, but is it going to benefit me is the real question.
Configuration: P200 MMX, 128 MB RAM, 4 GB HD.
Only getting 40 frames per second on PacMan.  Couldn't get the DOS drivers working, so even slower in pure DOS.  Running Win '98 and Mame32.
Suggestion/help/advice appreciated.  Thanks.
Trenchbroom
  • Last login:November 21, 2020, 09:25:43 pm
  • Wampus? Get over here!
Re:S3 Virge-VX (4MB) or ATI AIW Pro (16MB)?
« Reply #1 on: June 11, 2004, 11:42:16 pm »
Does the Virge VX have TV-OUT like the AIW?  Does it matter to you?
Are they close in price?  If they are ATI all the way.  16 MB will make a difference IMO, even on a P200.  In fact you shouldn't have to replace the AIW any time soon...TV OUT in case you go that route, 16 MB is just about perfect amount of memory for a video card (anything greater is probably overkill).  Better brand and probably more stable drivers as well.
As for your chugging pacman framerate--go get MAME .36 final.  It will play the old classics much better on old machines then the newer version.
Dougmeister
  • Dig-Doug
« Reply #2 on: June 12, 2004, 09:09:41 am »
Thanks for the reply.
Virge = no TV out.  And 'til I decide to buy a bigger monitor or a 20" tv, it doesn't really matter to 'cause all I have right now is an extra 15" monitor
I already own both cards... just don't want to go through the hassle of pulling the AIW (it's a 2ndary card on a dual-monitor machine), getting drivers, etc. if it won't really make a difference.  If you say it will, then I'll try it.
And as far as the 0.36 version of Mame32, will it work with my 0.83 roms or do I have to go back and pull out my archived 0.36 roms?
Dougmeister
  • Dig-Doug
« Reply #3 on: June 12, 2004, 09:41:26 am »
Also, anyone have the URL to download v0.36 final?
bloodyviking77
  • Last login:March 07, 2010, 07:01:38 am
« Reply #4 on: June 12, 2004, 09:11:20 pm »
www.mame.net/oldmame.html
And I think you'll find you will need to roll back your roms to the archived set.
Shut up! Bloody Vikings!!
SirPeale
  • Green Mountain Man
« Reply #5 on: June 12, 2004, 10:53:18 pm »
SLOWER in DOS?  What drivers couldn't you get working?  Sound?
And, as mentioned before, use .36 final, or VAntAGE.
Dougmeister
  • Dig-Doug
« Reply #6 on: June 12, 2004, 11:25:32 pm »
Sound worked fine, so I'm guessing the video drivers were hosed.  I downloaded the files from Gateway's web site, so unless it was just Windows drivers and not Windows/DOS as it said... I dunno...
All I know is that DOS Mame on this thing is a dog.
SirPeale
« Reply #7 on: June 13, 2004, 08:08:05 am »
Yeah, it's the version of Mame you're using, not the drivers.  In DOS, the only driver you should need loaded is the sound drivers.
Dougmeister
  • Dig-Doug
« Reply #8 on: June 14, 2004, 08:45:54 am »
Ok, thanks.  I'll grab 0.36 final DOS and give that a shot.
