Author Topic: Mame updating question.  (Read 1827 times)
Floyd10
« on: June 08, 2004, 05:01:29 pm »
I want to put an updated list of games from .82 into my .79 that I have. Is there anyway to do this without recompiling a newer more confusing version of mame? thanks
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re:Mame updating question.
« Reply #1 on: June 08, 2004, 06:32:21 pm »
  Firstly, you can do all that but most likely your .79 version of MAME won't run the updated ROMs correctly (if at all).  If you want to run the updated games you need to run the updated emulator.
  Secondly, there's no need to compile anything. Download the binaries from the MAME site.
-Steve
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: June 09, 2004, 09:32:16 am »
Not sure exactly what you are trying to do, but it seems like the easiest solution is to download 0.82 binary (or maybe you want 0.83 now) into a separate directory, put only the new game ROMS for 0.79u1 through 0.83 in there, use 0.79 for most games and 0.83 for the newer games only.
Or do you want/need to do something else?
Floyd10
« Reply #3 on: June 09, 2004, 03:07:54 pm »
ok, thanks. The binarys are confusing though  ??? Oh well, Im sure I'll figure it out.
Tiger-Heli
    • Tiger-Heli
« Reply #4 on: June 09, 2004, 03:16:36 pm »
The source files are confusing.  The binaries are set to go.
Assuming MAME 0.79 is installed in C:\MAME and you know the new games and have the new ROMS, (and know command prompt usage), it's this simple:
Create new folder C:\MAME083\
Download MAME 083 binary and extract to C:\MAME083\
Put new ROMS in C:\MAME083\ROMS
At command prompt, type
cd\
cd mame083
mame -cc
Open C:\MAME083\mame.ini and edit file pointers to point to C:\MAME\ whatever, match other settings to C:\MAME\mame.ini.
Setup your frontend and play new games.
Floyd10
« Reply #5 on: June 09, 2004, 03:30:33 pm »
ok, ty
