Author Topic: Got a cool idea to make a spinner...  (Read 2554 times)
Reg
  • Last login:April 27, 2004, 10:43:45 pm
« on: August 02, 2002, 09:26:15 pm »
Hi,
Later I was helping my girlfriend to clean
our garage and I have found a old bicycle wheel...
The wheel was unusable but the core where the bearings
are, seem to be fine...
So I cut the rod to isolate the core of the
wheel... the only problem is a wheel that go usually
at the back of a bicyle and the part that have a lot of
spike gave me some hard time...
What do you think of this idea to recyle a old bicyle wheel to make a spinner?
thanks
Reg
x-wing
  • Last login:March 28, 2003, 10:40:37 pm
  • I Built My Own Arcade Controls!!
Re:Got a cool idea to make a spinner...
« Reply #1 on: August 02, 2002, 10:14:46 pm »
No offense, but I don't think it's a very good idea.  I mean, why go through all the trouble, and then just to end up with a hacked up peice of junk on your control panel?  What kind of spinner knob would you find to fit a bicycle axle?  If all you are after is the bearing, just find a more suitable one at a hardware store.
I would just think that your money and time would be better spent elsewhere, that's all.
darkmanx
  • Last login:May 29, 2003, 04:46:57 am
« Reply #2 on: August 04, 2002, 10:54:34 pm »
you know...rollerblade wheel bearings could be a more viable option for ya.
WHELP! As if you knew what an eternity was. Grovel before your true master!
neuromancer
  • Last login:May 10, 2006, 04:26:57 pm
  • Can I Play?
« Reply #3 on: August 05, 2002, 10:27:24 am »
bicycle bearings are meant to work with the shaft horizontal. The one's i've had get hard to turn when you tighten them up enough to eliminate axial play.
Bob
Lilwolf
  • Last login:May 23, 2026, 10:51:22 am
« Reply #4 on: August 05, 2002, 11:08:28 am »
For making a spinner, you put the hacked part UNDER the control panel.
So if you can get it to work, it should look great!...
But I think the roller blade might actually work better.  Why?
easier to screw into the cabinet and smaller.
Also, you could take a second wheel and use it as the weight (after you stopped it from rotating that is.
