Author Topic: Removing Tape Goo from Lexan...?  (Read 2564 times)
RetroJames
  • Last login:December 10, 2021, 05:26:38 pm
« on: June 06, 2004, 07:44:28 am »
I had to make some adjustments on a lexan CPO with a router so I put that blue painter's tape over the CPO to protect it.  Most of the tape came off with no problems, but there is some residual goo.  What could I use to get it off that is not going to scratch the heck out o this CPO?  Thanks!
MameMe
  • Last login:June 08, 2005, 06:45:25 am
Re:Removing Tape Goo from Lexan...?
« Reply #1 on: June 06, 2004, 07:49:50 am »
I use an amazing product called "Goo Gone".  It removes any kind of "gooey" substance from anything with little or no effort.
Good luck.
pocketbikez
  • Last login:January 16, 2005, 06:23:36 pm
  • INSERT COINS
    • my arcade cabinets
« Reply #2 on: June 06, 2004, 08:35:46 am »
Contact Cleaner and a soft rag. you can buy this stuff in spray cans from the electrical supply section of home depot.
dont use a product called Goof Off, it will almost melt the surface of the plastic.
MameMe
« Reply #3 on: June 06, 2004, 08:40:46 am »
I've never heard of Goo Off but Goo Gone works on anything.
pocketbikez
  • INSERT COINS
« Reply #4 on: June 06, 2004, 08:48:46 am »
this is the Goof Off product. I tried it on a classic Robotron marquee and while it did remove the sticker residue, it also melted the entire surface of the marquee.
RetroJames
« Reply #5 on: June 06, 2004, 08:50:51 am »
DING DING - That did the trick!  Thanks!
MameMe
« Reply #6 on: June 06, 2004, 01:43:03 pm »
Our Canadian Tire stores carry Goo Gone, maybe Goo Off is the American cousin product or something.
Good to know still.  ;)
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #7 on: June 06, 2004, 05:53:40 pm »
FYI: WD40 should also work.  Tar & Bug remover works on glass & metal but I don't know if it would hurt plexi or not.
saint ganked my avatar.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #8 on: June 06, 2004, 06:01:42 pm »
Just to throw another (and CHEAPER) option out there:  If this is sticky adhesive type goo of any kind, find an aerosol can of any (did I say any?  YES I DID!) common household product such as hair spray, deodorant, lysol, etc (unless it's a cooking product, stay away from those, they usually have some oil-based product in them that negates their usefulness).  Spray it on the stuff and wipe with a clean towel/rag/sock/shirt/fabric.
I've used all three of the above mentioned things with no problems whatsoever, and it has WORKED each and every time.  You can stop your worrying if you can't find Goof-Off at your local neighborhood store.  If the method I'm advocating doesn't work, THEN go waste your hard earned dough on a "specialized" product.
If Lysol will remove three month old Duct tape residue from a fender without ruining anything, it will work for your purposes too.
Ken Layton
  • Guru
  • Technician
« Reply #9 on: June 07, 2004, 12:11:17 am »
Common household Lighter Fluid removes glue without harming plastics. Remember no smoking while using it though.
Tailgunner
« Reply #10 on: June 07, 2004, 01:34:58 am »
Goof off is 95% xylene and 5% denatured alcohol. It's a good solvent mixture but I'd agree that it's too strong for use on most plastics.
