Author Topic: Mame .83 out  (Read 2132 times)
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
Mame .83 out
« on: June 04, 2004, 11:22:35 pm »
MAME 0.83 has been released, and it supports 4953 ROM sets, 2806 unique games.
Here is the whatsnew.txt of 0.83:
0.83
General Source Changes
Misc Changes [Nathan Woods]
   src/inptport.c:
   src/inptport.h:
   src/mame.c:
       - Switched input_port_allocate() to use auto_malloc(), removing the
   need for input_port_free()
   src/windows/fronthlp.c:
       - Added an optional definition for the S_ISDIR macro for when it is
   not present
STV Update [Mariusz Wojcieszek]
   - added VDP2 layer disabling based on VRAM cycle pattern registers - fixes
   gfx glitches in shanhigw title screen
   - added VDP1 half transparency - improves sprites alpha blending in
   shanhigw in-game
   - added VDP1 Gouraud shading (for normal sprites only) - adds highlighting
   for selected tiles in shanhigw
Changed some names + years in segac2.c and playch10.c [Curt Coder]
Spiders NVRam [Justin Szczap]
tecmosys.c update [Tomasz Slanina]
   emulates some parts of vidhrdw but games still don't work due to protection?
Fixed cheat engine bug preventing assignment of controller buttons as activation keys [Ian Patterson]
Sega System 16/18 update [Charles MacDonald]
   - Added MSM5205 sample playback to tturfbl.
   - Added MSM5205 sample playback to shdancbl.
PSX updates [smf]
   heavens gate graphics issues & correct loading / banking.
   correct loading for super football champ ( now it's stuck in test mode ) and
   added later world version.
   taito fx1 watchdog ( address is unconfirmed, but hopefully soon ).
   pasted in taito fx1a readme
   pal support for mess.
   horizontal start/end
New Games supported or promoted from GAME_NOT_WORKING status:
Cannonball (Atari, prototype) [Stefan Jokisch]
   one ROM is missing from the only known PCB causing
   some GFX problems
VS. Gumshoe [Pierpaolo Prazzoli]
   banking fixed, game now works properly
Miss Puzzle [David Haywood]
   bad rom causes some gfx glitches
Greyhound Trivia (various sets) [Pierpaolo Prazzoli, Chris Hardy]
Heaven's Gate
New Non-Working games / clones supported
GP500 [R.Belmont]
   preliminary driver 'Hopeless Hardware' doesn't do anything yet
0.82u3
Fixed rendering issue with Magical Date [smf]
Fixed Sonic Wings Limited Lockup [smf]
Various changes [Nathan Woods]
   src/cpu/i386/i386.c:
   src/cpu/i386/i386.h:
   src/cpu/i386/i386ops.c:
       - Revamped interrupt handling; a bonafide line is now implemented
   and also implemented IRQ callback
   src/cpu/i386op16.c:
       - Fixed CALL absolute instruction under 16 bit mode
   src/drivers/seibuspi.c:
       - Fixed i386 interrupt call to use PULSE_LINE instead of always
   ASSERT_LINE
   src/inptport.h:
       - Added more MESS specific stuff within #ifdef MESS
   src/memory.c:
       - Added memory_install_*_handler_mirror() calls that I thought that
   I submitted earlier
   src/vidhrdw/tia.c:
       - Minor fix from the MESS side
   src/windows/input.c:
   src/windows/input.h:
       - Changed use_mouse to win_use_mouse and made it non-static
7810 improvements and sound in games on Metro driver :-) [Eisuke Watanabe]
   * 7810
   gta, gti, dgt fixed
   working reg opcodes fixed
   sio input fixed
   * metro.c
   added sound support
Fixed dariusg (broken by 68008 changes) [Curt Coder]
Argus (Gottlieb, Prototype)
Video Vince and the Game Factory (Mylstar, Prototype)
Wiz Warz (Mylstar, Prototype)
New Clones supported or promoted from GAME_NOT_WORKING status:
sfex2p (asia version, was usa) [smf]
Pinball Champ '95
   looks like its probably gambling based
   doesn't work yet so I don't know if any skill is involved
0.82u2
onetwo: Fixed glitch on Title screen [Pierpaolo Prazzoli]
   - colours could do with being checked on this
goal92: Fixed clock, visible area and found it's missing the adpcm emulation.
I tried to add it, but i had no luck, so if anyone want to have a look,
please do it ;-) [Pierpaolo Prazzoli]
I386 and Mame Debugger Enhancements [Nathan Woods]
   src/mamedbg.c:
   src/mamedbg.h:
       - Attempting to start a trace with non-existant registers will now
   raise a warning in the MAME debugger
       - Implemented mame_debug_trace_write() call, an API to allow
   injecting text into the trace files of the MAME debugger.
   src/cpu/i386/i386op16.c:
       - CALL16 opcode will now only adjust IP instead of EIP when in
   16-bit mode
       - Minor bug fix in RETF opcode
       - Changed REP and REPNE opcode implementations to use the same code
       - INTO will now interrupt even if IF is zero
Misc Improvements [Curt Coder]
   * Arkanoid et al
   drivers/arkanoid.c
   machine/arkanoid.c
   - Memory map merge
   - Moved paddle2 trickery to machine/
Nintendo 8080 hardware update [Stefan Jokisch]
The driver has now been split into three parts. A few features that have been missing
in Helifire since my last update are back, i.e. the flickering colors when you're shot
and the volume decay effect (this affects the melody at the start of a game and a few
tunes that can be heard during the bonus scenes every twelve attack waves). The
starfield should now scroll at the correct speed, it's only 75% of what it used to be.
Finally, I have decided to use the color prom from Space Fever in Space Launcher, I
think it's correct.
Change to eeprom_interface_93C46 [Tomasz Slanina]
   please check games using this to make sure non broke
Debugger: With this patch you can output traces to the console ( or grep etc ) by
typing: TRACE CONSOLE [smf]
ST-V updates [Mariusz Wojcieszek]
   - fixed bugs introduced in previous update: RGB sprites bad colors and
   incorrect sprite clipping
   - added color offset for RGB sprites
   - fixed horizontal scrolling for bitmaps (corrects mausuke ingame
   background)
Change to EEPROM_interface eeprom_interface_93C46 [Tomasz Slanina]
   please check games using this ...
Seattle Update [Aaron Giles]
   x86drc.c:
   * fleshed out SSE support
   * made it optional for recompilers to keep the PC/ICount in registers
   * made append_verify_code work for sizes > 4
   cpu/mips/mips3.c:
   * added support for the Config register
   * added support for new variants: R4700, QED5271, RM7000
   * fixed bug in LWXC1/LDXC1/SWXC1/SDXC1 instructions
   cpu/mips/mips3drc.c
   * extracted core codegen portion into new #include file mdrcold.c
   drivers/seattle.c:
   * added more extensive documentation on the various boardsets
   * added constants for the GT64010 and all interrupts
   * added ethernet device interrupt support
   * made the IDE controller visible on the PCI bus
   * formalized support for the "widget" board used in vaportrx & calspeed
   * hooked up CMOS protection bit
   * corrected sfrushrk audio CRCs and hooked up hard disk
   * marked sfrush and vaportrx as working
   machine/midwayic.c:
   * added support for sfrushrk PIC
   * added timeout on PIC reads to speed up sfrushrk
   * fixed missing sound reset latch at startup
   machine/smc91c9x.c:
   * new implementation of SMC91C94 ethernet controller
   * only loopback mode supported
   vidhrdw/voodoo.c:
   * cleaned up logging
   * all stats now accessible via the backslash key
   * got rid of ugly red/blue swap hack
   * fixed missing truncation on vertex coordinates (fixes vaportrx graphics)
   * added support for alternate LFB write modes
horshoes: fixed DIPS [Brian Troha]
PreGX Cleanups [R.Belmont]
6532 RIOT patch (fixes some things in MESS) [Judge]
Quiz Do Re Mi Fa Grand Prix [Eisuke Watanabe]
Quiz Do Re Mi Fa Grand Prix 2 [Eisuke Watanabe]
Many ZN Based games [special thanks to Tourniquet, Olivier Galibert, smf, R.Belmont
           , Malice, Renegade, Twisty, Dox, But & many other mame.net board users]
Victorious Nine [BUT]
Golden Par Golf [Brian Troha]
San Francisco Rush [Aaron Giles]
Vapor TRX [Aaron Giles]
Anteater (German) [Pierpaolo Prazzoli, MASH]
Monster Maulers [R.Belmont]
Heaven's Gate [R.Belmont]
   incomplete banking or psx bugs?
Gals Panic II - Quiz version [Pierpaolo Prazzoli]
Dingo (encrypted set) [MASH] -- bad rom
0.82u1
Made R3000 version of Area 51 parent set [smf]
memory.c patch [Nathan Woods]
   src/memory.c:
   src/memory.h:
       - Introduces
   memory_install_[read|write][8|16|32|64]_handler_mirror() calls, which
   install memory handlers that can mirror similar to the AM_MIRROR macro
STV VDP-1 update [Mariusz Wojcieszek]
   - converted VDP1 drawing (sprites) to use framebuffer
   - added sprite priorities (corrects shanhigw ingame and colmns97 title screen)
   - added color offset for sprites
   - improved sprites alpha blending (improves ejihon and shienryu intro)
   - added framebuffer interlace (fixes elandore character selection screen)
   - added color offset for bitmaps
   - added vertical scrolling for bitmaps (corrects shanhigw ingame)
   The main result (visible to user) of these changes is that shanhigw is now
   playable without problems (apart from gfx glitches on title screen).
STV VDP-2 update [Angelo Salese]
   fixed a window mode bug
Fixed PSX sio bug [smf]
Fixed Z80 RETN / RETI cycle counts [Juergen Buchmueller]
Fixed sound and dips in 1945kIII [Pierpaolo Prazzoli]
hyprduel.c sprite priority fix [Hau]
tecmo16.c flipscreen fix [Hau]
Bloody Roar 2 [smf]
   one rom is bad
FireHawk [Pierpaolo Prazzoli]
   actually still marked as non-working due to
   standard 'afega' hardware protection issues in attract mode
Shanghai - The Great Wall [Mariusz Wojcieszek]
   some glitches on the title screen
Head On (Irem M15 Hardware) [David Haywood]
   no sound
Target Ball (no nudity set) [David Haywood]
Open Golf Championship (ver EAE) [R.Belmont]
   not working
Pachinko Gindama Shoubu DX [Brian Troha]
Pachinko Gindama Shoubu [Brian Troha]
   hardware is similar to realbreak but they don't work yet
...they only live twice!...
(>")>----MAME----<("<)
MrBond
Re:Mame .83 out
« Reply #1 on: June 04, 2004, 11:24:09 pm »
note that list includes the 'u' updates from the official .82
