Author Topic: Will Daphne work on CGA monitor?????  (Read 1191 times)
koolmoecraig
    • My Intervention
« on: June 04, 2004, 05:26:20 pm »
Hello,
Will Daphne work without problems on a CGA Arcade monitor with an ArcadeVGA card?
Thanks,
Craig
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
Re:Will Daphne work on CGA monitor?????
« Reply #1 on: June 05, 2004, 07:52:14 am »
If by CGA you mean standard resolution arcade monitor, then yes, it will work.
JoeB
  • Last login:July 29, 2025, 05:37:14 pm
  • NES Fanatic
« Reply #2 on: June 05, 2004, 11:49:58 am »
Yes..
the original laser disc system only used CGA.
Make sure you use 640x480 and disable hardware acceleration in daphne.
