Author Topic: powering up a LS30 rotary interface?  (Read 1486 times)
thogar
  • Last login:August 21, 2007, 05:29:08 pm
« on: June 04, 2004, 01:17:39 pm »
Could anyone offer some advice on getting power from an IPAC4 to the LS30 interface from Druin?  I don't solder so I was hoping for a "room temperature" solution.  Thanks in advance.
alphasqorner
  • Last login:September 07, 2017, 10:55:43 am
  • The machine took my quarter!!!
    • AlphasQorner
Re:powering up a LS30 rotary interface?
« Reply #1 on: June 06, 2004, 04:15:24 pm »
my ipac 2 has a set of onboard pins that are used for LED usage that mimic the scroll/caps/num lock key LEDs (an LED harness can be bought from ultimarc.com to use these pins, but I didn't buy/use this harness).  Anyway, I just used two of those pins (one 5V and the other ground) to hook directly to the rotary interface.
hope that's clear, if not, I'll try to post pics if you need...
Visit www.alphasqorner.net: Home of AlphasQontroller (CP with "coin door-ed" stand)
