Author Topic: connecting ultimarc vga breakout cable to a scart plug  (Read 2505 times)
Dr_horror
  • Newbie
  • Last login:June 05, 2004, 08:08:54 pm
« on: June 04, 2004, 03:08:49 am »
Hi, I am confused about soldering the H and V wires from the ultimarc vga breakout cable to a scart plug as I want to connect the ArcadeVGA card to the scart socket on my TV
I have read that the H and V wires on the vga breakout cable must be joined together and then wired to  pin 16 and 20 on the scart plug
Please can someone explain exactly how to do this
MikeAlex
  • Last login:February 10, 2025, 02:06:29 pm
  • KIAAAAAIIII!!!!!!
Re:connecting ultimarc vga breakout cable to a scart plug
« Reply #1 on: June 04, 2004, 07:58:09 am »
Check this site. All is explaned in detail...And it works! ;)
http://www.jayma.org/mamescart/
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« Reply #2 on: June 05, 2004, 03:24:13 pm »
solder both H and V sync wires to pin 16. then solder a short length of wire to connect pins 16 to 20.
« Last Edit: June 05, 2004, 03:25:15 pm by rchadd »
ras2a
  • Last login:November 19, 2016, 02:21:26 pm
  • I drink, therefore I am!
    • Nolij
Re: connecting ultimarc vga breakout cable to a scart plug
« Reply #3 on: December 02, 2004, 10:06:04 am »
Just been looking for the wiring diagram for VGA > SCART.  The site linked to above does not work. (404).  Does someone have a link to a simple wiring diagram for this?
cheers
Craig
Lord Hiryu
  • Last login:September 29, 2020, 12:05:39 pm
    • Lord Hiryu's Artwork
« Reply #4 on: December 02, 2004, 12:55:07 pm »
This is the correct link of the same diagram:
http://www.ojosverdes.com/stormrider/mamescart/
Cheers.
Que tiempos aquellos, en el que las vidas se llamaban tanques !
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #5 on: December 02, 2004, 01:07:48 pm »
Note: there are 2 different SCART standards, European and Japanese.  The cable looks exactly the same for both but the pins are wired differently.  The site referenced above is for European Scart only.
ras2a
    • Nolij
« Reply #6 on: December 02, 2004, 01:41:24 pm »
Cheers for the link Hiryu.  Dave, I live in England so it's the European pin-out's I'm after.  Thanks for the heads-up tho
cheers lads
« Last Edit: December 02, 2004, 01:44:31 pm by ras2a »
