Author Topic: Where to go for ArcadeOS support? Here?  (Read 1253 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: June 03, 2004, 09:03:00 pm »
Got it working, but when I fire up a game (e.g., Puckman), I get the following error:
"Out of frequency range
Set resolution lower or see monitor guide"
I have a Compaq MV540 15" monitor.
I ran Fraggal's Mame Installer CD and chose Ensoniq sound card drivers, normal monitor (not tv or arcade monitor), and the Pentium I (i586) version of AdvanceMame.
Advice?
The monitor is set to 640x480 w/ a Vertical setting of 75Hz and a Horizontal of 37.6K, if that helps.  Can't figure out how to change that setting in DOS...
Re:Where to go for ArcadeOS support? Here?
« Reply #1 on: June 04, 2004, 05:45:44 am »
There is an ArcadeOS/MAMEWAH board at MAMEWorld.  It doesn't get many AOS posts any more, but Orclord and a few others might be able to help out.  Sorry I don't know the answer :(
Dougmeister
  • Dig-Doug
« Reply #2 on: June 04, 2004, 05:48:59 am »
Thanks, will check it out.
On 2nd thought, it may be an AdvanceMame problem or just a config w/ my monitor...?
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #3 on: June 04, 2004, 07:04:39 am »
You're right, this is an Advance Mame problem. Try looking through Las Vegas' guide to setting up AdvMame here.
It's been a while since I've set it up, but I'm pretty sure you just have to get ADVCFG and ADVV set up right (these take a little playing around with to get a regular VGA monitor working).
