Author Topic: Errata  (Read 7558 times)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Errata
« on: June 03, 2004, 09:44:36 am »
As I read the book I am going to post my ideas/additions here.
First, figure 2-7, making the curves.  There's a MUCH simpler way to make an inside curve and you don't need the grid.  Use a 3" hole saw.  That's what I did.  Make sure you drill before you cut out the side.  Then sand it smooth.
The outside curve by my marquee, I can photoshop up a step by step instruction on how to do that with a compass for the projectarcade website if you want.  Man, geometry class came back in a big way there :)   It's funny, I got to use my B.S. in Applied Math making my cabinet  ;D
I found my pic of my construction, throwing it on fe.mamehost so I can link to it :)
http://fe.donkeyfly.com/images/y_con2.jpg
The inside curve is a 3" diameter curve, the outside curve by the marquee is a 2" diameter curve.
BRB with a photoshop image of steps on using a compass to make a circle corner...
SirPoonga
  • Puck'em Up
Re:Errata
« Reply #1 on: June 03, 2004, 10:54:12 am »
As promised, but in low quality.
Conditions for this example:  Want to make a 2" diameter rounded corner.  Also we are assuming a right angled corner.
Step 1:
Starting from your corner that you want to round off use a compass set greater than 2".  Make marks at the edges.  2" could be used to save a step, but this way the marking lines are not confusing with some future lines.
Step 2:
From the intersection of the edge and marks from Step 1, anchor your compass on each mark and make a cross as shown.  Do not adjust your compass.  Keep it the same radius that was used in Step 1.
Step 3:
Now draw a line form the corner through the cross created  in Step 2.
Step 4:
From the corner in each direction mark off 2".
Step 5:
Draw a line between the two marks from Step 5.
Step 6:
Set your compass to 1" and anchor it at the intersection created in Step 5.  You now have a 2" diameter circle that should end up perfectly in the corner.
To do a circle that isn't on a right angled corner (usually near the bottom side of the marquee edges) do Steps 1-3.  Steps 1-3 bisect any angle, you might remember this from high school geometry class.  Then set your compass to the radius of the circle you want.  Then just use trial and error to figure out where on the diagonal line to anchor the compass.  You could use trigonometry and geometry to figure out the exact anchor point if you want to.
To cut the corner it is best to use a band saw or rotory tool (like a Dremel).  Then sand until you are happy with the results..
« Last Edit: June 03, 2004, 10:59:19 am by SirPoonga »
DeathMonk
  • Last login:April 03, 2015, 02:01:12 pm
    • MameStation.3
Re:Errata
« Reply #2 on: June 04, 2004, 11:16:43 am »
pretty good idea there sp
Now with cup beer holders!
