Author Topic: Need to consider fuses?  (Read 1358 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: June 03, 2004, 01:04:01 am »
If I set up a cab with a monitor that requires no isolation transformer, and everything else is MAME stuff (PC mobo, with PC power supply), should I be installing any fuse lines anywhere like arcade cabinets usually have?
NO MORE!!
Gameboy.au
  • Last login:January 11, 2005, 05:54:15 am
  • Cabinet completion: 65%
Re:Need to consider fuses?
« Reply #1 on: June 03, 2004, 06:49:49 am »
It's a matter of choice.
I would at least be installing one for the monitor, the PC will be fine through it's fuse in the power supply that's in the case.
The internet, hey... so they have that on computer's now???
« Reply #2 on: June 03, 2004, 07:28:02 am »
I have fuses in the mains plugs for everything (flourescent tube, monitor, PC).  These are plugged into a 4-way mains adaptor which is fused, and I have a fuse in the mains plug where the machine is plugged into the wall.
I don't know if US mains plugs are usually fused, but all UK ones are...
