Author Topic: Dimensions for control panel?  (Read 1985 times)
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« on: June 02, 2004, 01:56:43 pm »
Got a "Space Duel" cabinet, no control panel.
Ordered my joysticks, buttons, etc.
Found some 3/4" fine particle board that might do for my first attempt at a control panel.
Is there an easy way (existing template, etc.) to measure & cut the control panel or is it going to be a job where you have to measure the existing cabinet, draw up plans, etc.?
Bumblebounces
  • Last login:January 26, 2016, 07:57:28 pm
  • I ever tell ya 'bout Bumbles? Bumbles...BOUNCE!
    • Starbase 74
Re:Dimensions for control panel?
« Reply #1 on: June 02, 2004, 10:51:14 pm »
Get your tape measure out and go to town.  I am not aware of any premade templates but even if there were, would you really want to use them?  Be creative and use your imagination to make it happen.
Good luck
Bumble
Dougmeister
  • Dig-Doug
« Reply #2 on: June 03, 2004, 07:09:46 am »
Ok, thanks.  Thought I'd ask 'cause every time I start looking, I find all *kinds* of stuff out there that someone else has done before!
boesiii
  • Last login:November 22, 2015, 07:56:14 am
« Reply #3 on: June 03, 2004, 12:58:16 pm »
instead of using particle board as a first try why not try foam board
greywolf22
  • Last login:January 01, 2020, 12:45:06 am
  • My cab is always a work in progress
« Reply #4 on: June 03, 2004, 02:14:17 pm »
I agree, foam board works great, is cheap (Wal-Mart), and works as a GREAT drilling template (have to clean your hole saw out more frequently, but that stuff holds up great to drilling)  :)
Dougmeister
  • Dig-Doug
« Reply #5 on: June 03, 2004, 02:15:26 pm »
Hmmm... then once I get the shape and the holes the way I want 'em, just use it as a template for the real thing?
greywolf22
« Reply #6 on: June 03, 2004, 05:56:23 pm »
Exactly...that's what I did anyway...just clamp it down to the wood control panel and commence drilling  :)...seems to be a little more sturdy then regular card board, but that's just my personal experience...
