Author Topic: Controls/Wiring  (Read 987 times)
rpfinley
Controls/Wiring
« on: May 25, 2004, 02:43:40 pm »
Okay I want a 4 person, 6 button with a trackball set-up.  We're a little worried about soldering, whats the other solution?  I've seen things you can buy around $100ish, what does that involve?  If there is a solution under $200 that will save me time I am all for it, any suggestions?
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
Re:Controls/Wiring
« Reply #1 on: May 25, 2004, 02:46:08 pm »
Using an Ipac4 and female quick disconnects you shouldn't need to solder unless you plan on doing keyboard or mouse hacks.
unclet
Re:Controls/Wiring
« Reply #2 on: May 25, 2004, 02:52:10 pm »
I like the Hagstrom Electronics keyboard encoders (KE72 and KE72-T).    I like how it allows you to reconfigure the encoder via simple input file.    I have multiple BAT files (one for each of the emulators I have on my cab) and by simply executing a BAT file, I can reconfigure the KE72 on the fly thus remapping my entire control panel to that emulator's default configuration mappings.
Re:Controls/Wiring
« Reply #3 on: May 26, 2004, 04:57:43 am »
You can do that with an IPAC using the WinIPAC software too...
