Author Topic: Oh no.... where to solder!  (Read 3011 times)
Rob P
« on: July 29, 2002, 10:10:07 pm »
Alright.... four months after letting the parts sit around with no work done I've finally decided to start work on my control panel.... the problem is now that I took a look at the two Mad Catz Dream Pad's I purchased I realized they were different than what was on CD_Vision, so my question to the geniuses of this site is:
How do I go about identifying the various solder points on the board???
Oh please, point my ignorant self to any way to go about this...
Rob P
Re:Oh no.... where to solder!
« Reply #1 on: July 30, 2002, 07:03:17 pm »
bump
twist
  • Last login:December 06, 2002, 04:03:20 pm
« Reply #2 on: July 30, 2002, 07:59:49 pm »
Do you have any pictures of the insides? That might help..
1UP
  • Token Junkie
    • 1UPArcade
« Reply #3 on: July 31, 2002, 02:36:26 am »
It's usually just a matter of following the traces from the joystick and button contacts.  All the buttons should have 2 contacts, which are closed by a switch of some kind.  One contact is positive and one is the ground.  Just connect one contact to the NO on your arcade buttons/sticks and connect the other to COM.  Do this for each set of contacts.
The easiest way to solder wires to circuit boards is to drill a small hole (about the size of your wire) in the end of one of the copper traces (where it goes to the button contacts) and scrape away any green insulation from that area.  Then pop the end of your wire (preferably solid core wire) thru the hole and hold your soldering iron so the tip touches both the wire and the circuit.  After a second or two, start feeding solder into the joint, until you have a nice little bead of solder.  Withdraw the iron and hold the wire still for a few seconds while the solder cools.  That's it!
Good luck.
My other job...
Rob P
« Reply #4 on: July 31, 2002, 11:53:51 am »
Good luck.
Now THAT'S the type of answer I was looking for, thanks a lot :)
