Author Topic: How much t-molding?  (Read 2939 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
How much t-molding?
« on: May 24, 2004, 06:42:59 pm »
how much t-molding is required for a pacman style cocktail cab?
would the 20' be enough?
Apollo
    • Eight Bells
Re:How much t-molding?
« Reply #1 on: May 24, 2004, 07:00:44 pm »
More than enough you only need the T-molding to go around the flat top so unless your cocktail is going to be more than 5' square you will be fine.
rchadd
  • Made in Cornwall
« Reply #2 on: May 24, 2004, 07:07:37 pm »
the midway cocktail cabs have t-moding around 2 sides and also the edges of the CP's
http://www.klov.com/game_detail.php?letter=&game_id=8784
Apollo
    • Eight Bells
« Reply #3 on: May 24, 2004, 08:20:25 pm »
OK well if you are building one of those it looks like you will need more than 20'. Remember to have a bit extra for stuff ups.
Blakey
  • Last login:June 16, 2009, 09:28:31 am
« Reply #4 on: May 24, 2004, 08:39:46 pm »
Can't you just measure the bits you want moulded on your plans and then order that distance plus a little safety buffer?
3 of the 6 main panels of my cab are shown below, I added up the routed perimeter in CAD and found it to be 11m (~36'). As t-molding.com only sells in 20' batches, 40' is just right.
rchadd
  • Made in Cornwall
« Reply #5 on: May 24, 2004, 09:01:34 pm »
yes...if i had any plans (its on my todo list!)
just thought somebody else would know how much they needed to make similar cab...
Blakey
« Reply #6 on: May 24, 2004, 09:07:20 pm »
Pac-man style, here are the plans:
http://www.arcadecontrols.org/arcade_cabinet_plans.shtml#Kyle_PacMan
Even if you modify it slightly, it'll need almost the same amount of moulding.
