Author Topic: Happ vs. Imperial Trackball, What's the diff?  (Read 2297 times)
NoBonus
  • Last login:January 07, 2007, 06:48:58 pm
  • "Now that's a fine example of California's Gold"
« on: May 21, 2004, 06:03:48 pm »
What is the difference between Happ and Imperial trackballs? (besides $$)
NoBonus
NY_in_TX
  • Last login:February 25, 2017, 11:19:54 am
  • First play's free...next one will cost ya
Re:Happ vs. Imperial Trackball, What's the diff?
« Reply #1 on: May 23, 2004, 03:08:56 am »
I have a 3" one of each.  the differences....
functionally: nothing
physically: the betson/imperial is in a case sorta shaped like a football.  the happ is a more stripped down case (see the byoac.com main image)
feelwise (is that a word?):  the happs seems to be a tad more smooth.
overall: whichever one you find cheaper is the better one.   :P
again these are just my $.02 on my two 3" trackballs.
Goz
  • KOTA
« Reply #2 on: May 23, 2004, 03:28:59 am »
The Betsons are often less expensive.
If you do go for the Betson style you'll want to swing by Groovy Game Gear to pick up a booster kit.
GroovyGameGear.Com Link
Without the booster kit, it seems like it takes more spins of the ball to get accross the screen. (hard to explain).
The replacement wheels are metal instead of the flimsy plastic that Betson uses.
Other than the encoder wheel difference, I'd say Betson is the way to go... with the booster kit (opinion based on cost).With the kit, it is truly comparable to the Happs.
-Goz
(I am not affiliated with Groovy Game Gear)
« Last Edit: February 10, 2005, 10:37:56 am by Peale »
