Author Topic: Improve blocking/diagonal on Happ supers?  (Read 2096 times)
jaquer
  • Last login:January 13, 2025, 10:20:49 pm
  • Geek of no Qualifications
« on: July 28, 2002, 11:06:24 pm »
I've been playing with my new cab for about 4 days now and some of the people that have used it complain that both joysticks have poor registration on the left/down diagonal position (blocking down on fighting games).
I thought I remembered reading a post here a while ago on how to imrprove this but I can't find that post now.
Anyone have any idea how to do this?
TIA.
It's pronounced hacker.
x-wing
  • Last login:March 28, 2003, 10:40:37 pm
  • I Built My Own Arcade Controls!!
Re:Improve blocking/diagonal on Happ supers?
« Reply #1 on: July 28, 2002, 11:33:34 pm »
The diagonals on a Super are less responsive if you have the small side of the hourglass-shaped actuator toward the base.  If you are already set in 8-way mode (big end of the actuator toward the base), then check the levers on the microswitches.  The levers could be bent, causing them to be less responsive.
