Author Topic: Stern coin doors  (Read 2277 times)
greywolf22
  • Last login:January 01, 2020, 12:45:06 am
  • My cab is always a work in progress
Stern coin doors
« on: May 18, 2004, 06:57:35 pm »
Hey all,
I have an older stern coin door that came with my cabinet...the problem is that there are no coin mechs for it.  Is there any place that anyone is aware of where I can purchase just the coin mechs for this door...or do I have to find another stern door and pull the mechs off of it.  If I have to replace the door that's fine, but I'd rather not if I don't have to.  Any help would be great.  Thanks  :)
SirPeale
  • Green Mountain Man
Re:Stern coin doors
« Reply #1 on: May 18, 2004, 08:57:57 pm »
Most coin mechs are universal.  You can get them new from Happ or used from eBay.  I've got some, but I'm on vacation...
Ken Layton
  • Guru
  • Technician
Re:Stern coin doors
« Reply #2 on: May 19, 2004, 12:39:56 am »
Stern used standard off-the-shelf mechs from all the major coin mech manufacturers (mostly Coin Mech and Coinco brands). You can order brand new mechs from Happ Controls.
greywolf22
Re:Stern coin doors
« Reply #3 on: May 19, 2004, 02:03:50 am »
Thanks guys, that was the answer that I was hoping for.  :)
dogg0
  • Last login:December 14, 2014, 01:18:29 pm
  • ALL? no ALL!!!
Re:Stern coin doors
« Reply #4 on: May 19, 2004, 01:46:24 pm »
I have a stern cab without a coin door. I want to put just a black metal door on it (no coin slot), will the happs pinball blank door fit? http://www.happcontrols.com/coindoors/40006700.htm
is there a better option?
thou shalt not supress flatulence
-the bassmaster general
Ken Layton
  • Guru
  • Technician
Re:Stern coin doors
« Reply #5 on: May 19, 2004, 05:48:41 pm »
No, Stern's coin door was much bigger than regular coin doors. They had a much bigger hole cutout in the front of the cabinet. If you wanted to make some wood or metal 'spacers' then you might be able to fit a modern Happ door.
dogg0
  • ALL? no ALL!!!
Re:Stern coin doors
« Reply #6 on: June 06, 2004, 10:47:37 pm »
ok, i still havent found a solution, i might  just try to find a stern door and edit somehow, my basic goal is to replace the aproximately 12.5"x12.5" with a blank door to access a dreamcast, looking for any ideas. maybe a stren door frame?
Ken Layton
  • Guru
  • Technician
Re:Stern coin doors
« Reply #7 on: June 07, 2004, 12:18:49 am »
Entropy or Coin Mech might have a larger door now that may fit your cutout. Check with them for specs.
dogg0
  • ALL? no ALL!!!
Re:Stern coin doors
« Reply #8 on: June 07, 2004, 01:41:25 am »
know of any online retailers that sell those brand coin doors?
Ken Layton
  • Guru
  • Technician
Re:Stern coin doors
« Reply #9 on: June 07, 2004, 02:01:32 am »
You can buy direct from Entropy (www.entropyusa.com). Entropy and Coin Mech are distributed by Happ Controls, too.
« Last Edit: June 07, 2004, 02:35:55 am by Ken Layton »
dogg0
  • ALL? no ALL!!!
Re:Stern coin doors
« Reply #10 on: June 07, 2004, 02:33:45 am »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=26197&item=3819037125&rd=1
anyone know about these? looks like big enough, just dont understand how it locks (flat head screw driver?) I could probably drill through and add my own barrel lock.
« Last Edit: June 07, 2004, 02:37:29 am by dogg0 »
Ken Layton
  • Guru
  • Technician
Re:Stern coin doors
« Reply #11 on: June 07, 2004, 02:39:03 am »
That thing looks like it mounts in a wall. Yes, it appears to 'lock' with a screwdriver.
