Author Topic: Emulaxian/Fe-3darcade 0.66 custom arcades with a working jukebox, a movie thea..  (Read 6591 times)
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Emulaxian/Fe-3darcade 0.66 custom arcades with a working jukebox, a movie theatre and more!
0.66:
-Use any custom model as the arcade environment! This can be anything from a simple box to a complete reproduction of an actual arcade.
-Support for a working Jukebox in any arcade! Select mp3 playlists on the jukebox itself and watch that record spin! ;-)
-Support for a movie theatre in any arcade! Select movies on the moviescreen...
-Support for gates in any arcade! Menu's can be overlayed on any texture and go from one fpsarcade to the other without leaving the 3d environment!
-A demo arcade (fpsdemo2) that shows how to use these new features.
-Jump bij letter, game search, history search, and im most cases filtering are now much much faster.
-Filters can now use whole phrases instead of only words.
-Filters can now use larger, smaller, equals, notequals, contains and notcontains as operators.
-Optimized the paging menu, yeah the fe also has a normal menu system! ;-)
-The mame parser now works with long folder names.
-Cleaned and optimized the feutilities to generate game/music/movie lists from the contents of a folder.
-Fixed the 3 known bugs from the 0.65 release.
-Thanks to Dave Dries, www.cinemarcade.com, for letting me use his mame logo movie as an animted texture in the fpsdemo2 arcade.
screenshots of the fpsarcade demo 2 with jukebox:
http://www.i-modernist.com/fe3darcade.jpg
and in fullscreen arcade mode:
http://www.i-modernist.com/fe3darcade2.jpg
websites:
http://3darcade.mameworld.net
http://www.i-modernist.com/emulaxian
Peter
« Last Edit: July 27, 2002, 10:52:39 am by )p( »
Random24
This looks great!! I've tried it out on my desktop PC and I love it.  I now have to try to figure out all the options and setup.  I did seem to have one problem though.  When I set it to full screen I gor script errors when I approached a cabinet.  When it was in the rounded frame it would play the realplayer videos just fine though.
)p(
You found the first bug :-) There will be an updated exe available in a week or so that will fix all reported bugs for this release...
Until then keep arcadefull to false in fe.cfg and toggle fullscreen view with the karcadefull key (default=0) that will work without errors...
Peter
)p(
Peter
can't stand any bugs in my fe even small ones  ;)
so here is a fixed exe...http://3darcade.mameworld.net/fe066bugsfixed.zip
if the link does not work you probably have to type that into your browser...mameworld does not like to be externally linked ;-)
peter
« Last Edit: July 29, 2002, 10:16:11 am by )p( »
