Author Topic: Trackball.......  (Read 2745 times)
Darke
  • Last login:October 06, 2002, 03:26:23 am
  • Master Of The Obvious!
Trackball.......
« on: July 26, 2002, 11:25:43 pm »
I was wondering what you guys thought about replacing the plastic trackball with an 8-ball from a billiards set.  The 8-ball is heavier and so therefore will likely spin better.  I am having some problems with my new trackball I got from Happs.  Its a 2-1/4 PS2 interface.  The thing will not spin like it should.  Can't even play Marble Madness too well.  I sent Happs an email about it.  Maybe the bearings are defective.  What do you guys oil your trackball bearings with?  I know you cant use grease....its too heavy and the thing will never spin after that.  Any ideas or suggestions on this topic will be appreciated.
Wherever you go, There you are.
OSCAR
    • Oscar Controls
Re:Trackball.......
« Reply #1 on: July 27, 2002, 12:27:41 am »
A billiard ball should work very well in place of a standard trackball.   Quality billiard balls are made from a phenolic resin which is denser than the cast polymer that trackballs are made out of.  Just make sure you use a 2-1/4" billiard ball and not a 2-1/8".  I'm no expert in this field, but I believe that there are two different sizes.  I believe that cue balls and bumper pool balls are 2-1/8", but you should verify that.
For the bearings, light household oil works best for trackballs.  3-in-1 oil is what is typically used on trackballs, because (as you mentioned) heavy oil or grease only adds resistance.  Shelf life of trackball bearing lubrication is about 1 year without use, meaning that you should lube the bearings once a year even if you don't use it.  The oil will leak out of the bearings in the form of a light film and you may not even notice.  Under heavy use, it is recommended trackball bearings be oiled every 3 months.  A few drops on the dust shield next to the inner & outer race should be sufficient.
Darke
Re:Trackball.......
« Reply #2 on: July 29, 2002, 02:39:30 am »
The main thing I am looking to improve on is the spin of the trackball.  It doesn't spin very well now and I was thinking added weight of the ball would help that.
