Author Topic: Controls.dat Downloads Failing  (Read 1495 times)
MisterB
  • Last login:May 05, 2025, 10:12:16 am
« on: May 15, 2004, 09:24:12 am »
Hey controls.dat guys...when I try to download the XML version of the database, I keep receiving the following message
Code: [Select]
<b>Fatal error</b>:  Maximum execution time of 30 seconds exceeded in <b>/home/httpd/vhosts/fe.donkeyfly.com/httpdocs/controls/generatexml.php</b> on line <b>116</b><br />
Is this something you can fix?  Thanks!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Controls.dat Downloads Failing
« Reply #1 on: May 15, 2004, 12:52:23 pm »
Hmmm, it's timing out now?
I just tried it, it didn't timeout for me.  It generated the xml file on the fly.
Try it again, otherwise here's a link to an xml file I just downloaded.  You will need to fix it, there are some characters causing it to not be a valid xml file.  I have to look into that.
http://fe.donkeyfly.com/controls.xml
Hmm, IE doesn't like it, but mozilla opens it without any errors.  So you might have issues reading in the xml data.  You may have to delete the offending characters until I figure out what's going on.
MisterB
« Reply #2 on: May 15, 2004, 01:40:16 pm »
Hmmm...I was trying to DL it with IE, so maybe that's it.
Either way, thanks for posting the file!
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #3 on: May 15, 2004, 02:20:43 pm »
Last week I'd been having trouble downloading the no-white-spaces XML version, it was just giving me a 0kb xml file that wouldn't open. Seems to be working now though. Very strange.
SirPoonga
  • Puck'em Up
« Reply #4 on: May 15, 2004, 03:24:13 pm »
This will all be solved *hopefully* in the near future when there is enough games and I have enough time to convert the system into a more static file generating system.
