Author Topic: Need urgent help  (Read 1764 times)
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
Need urgent help
« on: May 13, 2004, 08:58:11 pm »
My roms came in the mail today, apparently alll for version .81. i put them in, (13 cds) and pasted them all to the rom folder in my mame 32 folder. I then opened mame 32 and the games still dont work? what am i doing wrong, i really need help, if you dont wanna write it in this forum just email me....
R.f.Banks@worldnet.att.net
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
Re:Need urgent help
« Reply #1 on: May 13, 2004, 09:43:21 pm »
I do not use Mame32 so I can't be of much help, but since no one responded yet I could try something.  Most emulators have a setting for where the ROM's live, make sure that is pointing to the folder where you put them.  Also, some front-ends need to "compile" the Roms list - basically take an inventory of what Roms you have before you can actually play them, look for something like that.  Other than that, you might be best going to the Mame32 website, see if they have a FAQ list or message board where people may have had the same issue as you.
:) Rotate or die! :)
Goz
  • KOTA
Re:Need urgent help
« Reply #2 on: May 14, 2004, 12:33:18 am »
Are you running MAM32 v81 ?
other than that check paths.
-Goz
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
Re:Need urgent help
« Reply #3 on: May 14, 2004, 07:44:27 am »
Did you audit your games? If you haven't audited your games they won't be listed.
Select "file" from the pull down menu and select "audit all games".
Hope that helps!  ;)
All Your Base Are Belong To Us!
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re:Need urgent help
« Reply #4 on: May 14, 2004, 08:01:17 am »
Maybe press F5 to refresh your games list. And as ReBirth says, make sure it knows where your roms folder is in the Directories setting (by default its set to Mame32/roms , so thats where your roms should be if you havent changed it)
