Author Topic: Knob on new power supply? - Thanks!  (Read 2280 times)
Snakebyte
  • Last login:September 18, 2014, 11:06:18 am
  • I'm building my own arcade controls!
« on: May 06, 2004, 02:04:31 am »
So the power supply on my Capcom Bowling decides to die.  No problem!  I'll just order a replacement from Bob Roberts...
I get my new power supply and it has this knob on it, obviously for some sort of voltage adjustment.
My old power supply didn't have one.
So the two questions are:
Does it make a difference if my old one has a knob or not?
and
What is the knob for?
High quality illustration below:
« Last Edit: May 06, 2004, 01:14:27 pm by Snakebyte »
Apollo
    • Eight Bells
Re:Knob on new power supply?
« Reply #1 on: May 06, 2004, 02:14:52 am »
Firstly no it doesn't make any difference and secondly the knob is usually a pot to vary the output of the +5V connection between 4V and 6V.
Snakebyte
« Reply #2 on: May 06, 2004, 02:20:05 am »
So I need to set that pot at 5V then since the old one had no adjustment?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: May 06, 2004, 02:22:40 am »
Your old one had an adjustment trimpot, too. It's recessed in the hole above the terminal strip.
Apollo
    • Eight Bells
« Reply #4 on: May 06, 2004, 02:56:14 am »
Just set it to half way and you'll be fine.
Snakebyte
« Reply #5 on: May 06, 2004, 01:13:32 pm »
Yes!  Bowling once again!  Trackball games rule!
Thanks for the help Apollo and Ken, much appreciated  :D
Bitnerd
  • Last login:July 07, 2004, 08:12:28 pm
Re:Knob on new power supply? - Thanks!
« Reply #6 on: May 06, 2004, 03:17:54 pm »
Hey Bro,
I am glad you asked this question.  I am getting in the supplies I need to build a supergun to test jamma boards and I picked up one of those power supplies from Bob Roberts. (he lives right down the street from where I work)...anyhoo, saw the knob and had no clue.  Good info on here as always.
Cheers,
Bitner
« Last Edit: May 06, 2004, 03:18:37 pm by Bitnerd »
All that glitters is not gold...
All who wander are not lost
Ken Layton
  • Guru
  • Technician
« Reply #7 on: May 06, 2004, 05:51:36 pm »
Turning the knob towards the "H" (for higher) turns up the voltage.
Rocky
« Reply #8 on: May 07, 2004, 11:26:30 am »
You really should adjust this knob with a meter handy. I wouldn't just set it half way  :P  Games will lock up or fail in other ways if the voltage is too far off
with the game on, test 5v and ground on the edge connectors.
